Ok don't shoot me because everytime I look at this I have to go off memory and I'm not an engineer.
These screen shots should give you a better idea of what Alfa can do.
1 and 2 screenshot make sure are turned on
If this is intended for zacbar, then this method (the dedicated DRL pics) won’t work for him. He’s got quads now and is swapping in projectors. I’m only *assuming* that he’s going to use some sort of conversion harness that plugs into his existing bulb connectors. This means that the dedicated DRL circuit won’t be there at his new projectors. This method DOES work for those that have projectors from the factory, and it IS the method as if the dealer were to add the sales code.
@zacbar, this is the method you are going to want to use (copied and pasted from the known working list):
CBC Features: DRL Configuration Select “Optional DRL”
CBC Features: DRL Lamp location (several to choose from, high beam, low beam, fog lamp, dedicated and SRT Light Bar) Known working high beam, low beam, turn signal and fog lamp.
CBC Features: DRL Dropout Enabled
Select “yes”
ECU3: DRLCustomerSettingEnable/Disable Select “yes”
Custom settings menu: DaytimeRunningLightsCSM Select “yes”
For location, you’ll want to choose “turn signal”.
