DRL On in daytime
Status
Not open for further replies.
BKass
Australia
Hi Guys,
A proud 2023 1500 Limited owner in Australia, I have been trying to have the DRL on in daytime, but no go....
Anyone had this issue? and how did you overcome.
Also how do you get the mirrors to auto fold when locking and unlocking the RAM via the keypad?????
SitKneelBend
St. Louis
3.6 Pentastar
Hi Guys,
You can set these features using AlfaOBD if you have it. Do you see the DRL option in your radio?
Administrator
DRL lights should be on any time the vehicle is in gear and the parking brake is not set.
As others mention there is probably a setting in the radio to enable/disable the DRLs.
The DRLs can be set for the Low Beam, High Beam, fog lights, dedicated or running lights using AlfaOBD.
04fxdwgi
Coastal NE North Carolina
2016 1500 Sport
If you don't have the auto power fold option on your screen, AlfaOBD may be used to set the feature. I know it did in my '16, but not sure about a '23.
Set the "Auto Power Folding Mirrors CSM Present: No", to a yes. Turn off ignition open door so radio shuts down and then that option should show up on radio screen shortly. Then you can toggle / off as desired
Think the "D" in DRL means "daytime", no matter where you are.
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
I believe that DRLs are only Mandatory in Canada
I do not know if that is in Every Providence
In the U.S. , many dealerships will tell you that it can't be added
They are just LAZY & can't be bothered
The 1st step is to change the settings to "For Use In Canada" in the Dealerships WiTech or what ever they use now to check software
Somewhere online, there is a PDF file on how to do it
I know that i have seen it posted on this Forum & over on the Z
I found something that sort of applies
Dealership would do this ...
AlfaOBD APP
Hagar1
Ontario Canada
2012 Ram 1500
AlfaOBD APP
Daytime Running lights have been mandated by the federal government back in around 1990. All of Canada! I think from personal experience from spending a lot of time on the road, DRLs are a great idea. On coming vehicles are far more visible and from a further distance.
ramffml
ramforum
DRL are lame AF. I turned mine off in Alpha ODB .
They're not for you to see better, they're so that others can see you. And having them off when everybody else is running them is not exactly the "brightest" (heh) thing to do because you're less visible to grannies and others with poor or careless vision.
DILLIGAF
Canada
What's next, you're going to tell me running smoked out lenses is a bad idea as well :321: IDGAF buddy. I dont have them on my 1953 either.
You must be fun at parties :manos:
zrock
canada
Obviously you do not care about other people's safety just how cool you think you look. What is it hurting to have DRL active is it hurting your truck somehow?
DILLIGAF
Canada
We should remove all pre 1990 vehicles off the road immediately! Because " safety " GTFOH ! What's next, you will tell me I should of added ABS brakes, Seat belts , DRLs on my Rat Rod so you can feel safe.
If you to old and blind you cant see a full size lifted truck coming down the road, You're the problem not me.
markabby
Monticello, Kentucky
2020 Limited
mine are on 24/7/365 i do it because i want people to see the truck. i also run the fog lights as well.
wife drives the truck and i want her to be safe.
personal preference on one's vehicles lights doesn't make them an idiot. Saying that, now many are adding all those LED light strips to the front and underneath., including behind the wheels.
a young girl owns this....
ramffml
ramforum
It's going to be your problem when they hit your truck.
GTyankee
3.0 ecodiesel
Down here just outside of San Diego ..
On a few of the 2 lane country roads, they have Mandated that DRLs shall be ON, 24/7
These particular roads are narrow & curvy, they have the Highest Accident rate of all the roads in this area.
Honestly, almost every brand of car/ pickup leaves the assembly line with DRL option
Only Chrysler products here in the USA do not leave the factory with DRLs
Because of a Violation, my Ambient Light Sensor is Covered & my Headlight Switch is set to AUTO
Arizona Sign
California ( old sign)
the Law:
This is where they nailed me.
In Court the Judge agreed with me about Chrysler products should have the DRL option,
He cut the FINE Price, i had to pay 1/3 of the normal fee.
, certain stretches of road in California require daytime headlight use. These are usually mountain roads or crash-prone highways such as Highway 67 between Lakeside and Ramona. When you see a black-and-white sign that says “Daylight Headlight Section” or “Daytime Headlights Area,” it’s a mandatory rule enforced by California Highway Patrol.
Hagar1
Ontario Canada
2012 Ram 1500
Not picking a side here just noting that, in Canada, day time running lights are law. There have been people charged for disabling or otherwise not using them.
ramffml
ramforum
Why would anyone go out of their way to disable them though, that's the question. "sticking it to the government"? I hate overreach as much as the next guy but this is a non issue, it doesn't cost you a thing financially or otherwise to just leave it as it came from the factory. Not worth getting bent out of shape over it.
Hagar1
Ontario Canada
2012 Ram 1500
Years ago I was approached by a law enforcement agency that wanted to disable the DRL on one of their unmarked surveillance vehicles. At that time, I contacted the folks in Windsor for info and they had an absolute fit. They wanted all the vehicle info especially the VIN. I conveniently forgot to send the info. I told the police "how" to do it but I would touch it nor would I allow any of the techs to touch it.
Jim BB
Hamilton ,ON
2019 Ram 1500 classic Express
I live in Ontario Canada where DLR ( DayTime Running Lights ) IS THE LAW ! many vehicles came from factory with them using the front Marker (signal) lights and done some research and found that I can move mine from the low side of the high beam to the marker (signal) light and still be legal and seen ! so that is what I did ! I also run LED lights through the whole truck ! I do like to be seen ! just because it is a truck Don't mean that you will be seen coming down the road !
Just putting in my thoughts and 1/2 cents worth !
Status
