DRLs installed
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
Took advantage of a nice afternoon (in between the rain) to install my DRLs.
These are hooked up on a 5 pin relay, to allow them to turn off when the parking lights are turned on. :rocking:
video of them working:
[yt]fMf2h2lVSKU[/yt]
Not a bad install, just found a fuse to tap into for power to the relay, couple grounds, splice into the parking lights, bam. :D
And a couple pics here too:
Now hopefully these assholios out here will see me.....tired of about loosing my front end on idiots!
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
I can't wait to get out and park somewhere, see how far away I can see 'em. They'll be on when I remote start the truck, so that will make it easy to see! :D
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
pic of them at night here. Yup, I'll be putting another set on as backup lights as soon as I can!
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
oh yours will put these to shame, but I wouldn't run yours on the street! LOL
LB3711
Trumbull, CT
3.6L V6
oh I will only run them like I would when I pt the highs on. I need to get the aux panel to keep it clean inside
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
I just bought one........its sitting in the pass seat on the truck. LOL
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
nope. its going on the truck......sometime.
I'm going to use it on the reverse lights. probably. :D
09SMOKINHEMI
TEXAS
That looks very nice!! Was that black piece hard to take off your bumper?
sent from my Samsung Galaxy S3
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
nope!
I've had it out before (when I swapped bumpers), so I remembered how it came out.
Basically, you have 6 push pins in the top. They have a pin within a pin setup. A trim removal tool works great to get those out. Then, the bottom has a couple of inner "clips". push up on those and the thing pops out.
Pretty simple on the removal. Install was easier. :D
And, if you don't run a front plate........the DRLs will fit in the smaller section in between the "tow hook" area. Just depends on what you are after for looks there.
09SMOKINHEMI
TEXAS
Good stuff man. I think I'll be doing your setup :D
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
spiffy!
Here's some notes for you. Wiring genius comes from myoung - I suck at this stuff!
here's what you'll need:
- 5 pin relay and pigtail
- little bit of extra wire, depending on your application. I needed about.....16" more for my run to the fuse box.
So, here's what I did
Pins:
30 - ran to the fuse box - I found one that comes on when the truck is running
85 - ground
86 - parking lights (or whatever you want it to trigger "off" from
87 - 12V from the xDRLs
87a - not used for this
I found a fuse in the box that came on with power:
the codes
Houston, Tx
Magnum 5.2
man I really like these, gonna have to invest in a pair for the front and maybe one for the rear when I get back to work
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
I wish I had the back ones on! LOL backing down my driveway is fun.......love the LED drop in bulbs I have, but these would make it killer!
stevenmicheal
