Duel Exhaust?
Ryan
So Im getting Magnaflow Exhaust installed and the guy asked me if I wanted true duel exhaust from the cats back or run single pipe to the muffler then split to duel pipes... What is the best for performance?
macmongrel
Alaska
I don't think its necessary to do true dual...itll just be a lot more expensive...
EDIT: OOPS MY Bad Wrong year Exhaust kit Deleted
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Far as the kit goes if your not looking for full on performance get a Single in/ Dual out muffler of your choosing and 2 tips however you want them to exit. I would suggest getting them to put in a new Y pipe to help the truck breathe alill better.
Ryan
Ryan
I was wanting to go with True Duel.. That would be the best for performance right?
WhiteExpress
Midland, TX
True dual exhaust is really not necessary for a stock / near stock truck.
What gains might you see? I don't know 4 HP difference?
If you had nice long tubes, and wanted a dual setup with an X or H pipe I could see it.
I'd put the money elsewhere.
dodgedaddie
Maine
Go full duel..
If the engine breaths,,It performs,,(if an H or X ) Pipe even better..:drool:
'WhiteExpress", ,,What were you thinking for performance cains !!?
Budakane
Northern VA
345ci Hemi
true duals on a stock truck will yeild no gains, and will lose you some ponies down low. I run long tubes, 3in Y, and a 3in single all the way back, I know I have alot more mods, but truth is unless ur running boost there is no need for true duals. I have my cutouts right after both long tubes, for that exact reason(similar ro Chefred112)
