DVD player on powers down manually
brobinson1283
I just did a Double Din dvd player install. Everything works, powers up etc. However, when I turn off the ignition and remove the key the thing stays on. I have waited and waited and still on. I can power it down holding the power button, and then it turns off. If I press the power on though it wont turn off. Its almost like a power delay? Not sure. Any thoughts?
1500ram12
5.9L Cummins
How long are you waiting? Did you open the door after you turned the truck off? There is a roughly 30 second delay by fault or if you open the door before the 30 second.
Sent from my VS985 4G using Tapatalk
baum
savage, mn
2015 Laramie
what module are you using? if it is staying on after you open the door most likely a bad module
brobinson1283
brobinson1283
I used part Axxess XSVI-6523-NAV for this.
1500ram12
5.9L Cummins
Double check your power and accessory wires. If those are good try throwing the factory radio in and check that it powers down. What radio are you replacing? Ra1 3.0 or ra2 5.0? What radio are you installing
rthorsten
Does it go off when you open the door?
Are the sure the two power wire are hooked up correctly. Yellow to Yellow, red to red, one is constant and the other is aux maybe you got them backwards for some reason.
brobinson1283
brobinson1283
Yea its set up yellow to yellow and red to red. It does not power down when I open the door
rthorsten
It sound like a power issue to me. It seems you are on a constant power not the aux. It could be a problem with the axxess harness. The easy way to find out is un hook the yellow and red connection between the axxess harness and the head unit. They run a jumper from the factory red and yellow to the head unit. IF it turns off when you open your door then you know your problem is with the harness.
baum
savage, mn
2015 Laramie
there is NO accessory on the factory harness. its canbus controlled hence the reason you need the module. the canbus system in these truck tell the radios when to turn on and off.
sounds like a bad module to me.
brobinson1283
brobinson1283
The radio worked fine before. Does anyone know if I can bypass that module with the red wire only? The place I got it from wants me to buy a new one. Get ra # for old one. Return it. Etc. just trying to avoid uninstalling completely and starting over.
baum
savage, mn
2015 Laramie
cig lighter.
however i dont know if it will stay on until you open the door or turn off when you shut the truck off.
brobinson1283
brobinson1283
I was just thinking of finding the red power wire before it hits the new harness. Cut it and splice it to the red wire going into the dvd player. This would bypass that module. I just dont want to hurt the deck. Not sure what that module does.
baum
savage, mn
2015 Laramie
like i said before the truck has NO switched power at the radio its controlled through the canbus system.
the module converts the canbus signal to "usable" sources for the radio (12+ switched, reverse trigger, speed sense, e-brack signal)
brobinson1283
brobinson1283
Excuse the stupidity lol. But does that mean I cant do what I proposed?
baum
savage, mn
2015 Laramie
NO you CANNOT do what you wanted. there is NO accessory wire at the harness. you either have to get it from a different location in the truck or deal with returning the module you got.
CMSBusDriver
