GORDONS
Got a notice in my truck to stop driving it, there's a recall for a brake clip. Naturally, not believing there was anything to worry about I drove to the dealer to pick up a battery for my Dakota then asked the svc dept guys what it was about. No kidding, the pushrod through the firewall is flat on the interior end and a drilled hole fits over a stud sticking out 90degrees from the upper part of the brake pedal and is retained by a flat clip. Turns out, a stretch of Rams made it out the door without those clips and it's a matter of time before the pedal disconnects from the pushrod and the brake pedal does nothing. The technician told me they'd had one on the lot pop its linkage. Easy enough for him to look and confirm mine was present and seated properly, it's a 2020 Warlock and I didn't ask which versions were affected---presumably you will get a notice if you've got one of them.
