Eco Diesel Exhaust
Thomas46
Hernando, ms
Eco diesel
2014 Eco Diesel, fuel pump implosion, replace along with injectors. Now exhaust is heavy and black. Any ideas why?
Administrator
If I'm not mistaken, the HPFP has to timed correctly??
Are you deleted? Something has to be seriously wrong for thick black smoke to make it through the DPF. If you are tuned, you may need to have it updated to for the new injectors??
T
Thomas46
Hernando, ms
Eco diesel
I am deleted. Thanks for the advice. I will take it back to the shop Monday.
Shawn226
Mercer County, Pennsylvania
3.0L EcoDiesel
Like crash said. Excess smoke is always due to extra fuel being injected and lack of complete combustion.
I get a little bit of smoke every now and again when hammering on the pedal and going uphill, GDE confirmed it’s normal, but if you’re talking smoking like an old coal train, I have not had that issue yet
T
Thomas46
Hernando, ms
Eco diesel
My eco with dark smoke still at shop. They have sent brain to be retuned . Hope this helps.
Administrator
My eco with dark smoke still at shop. They have sent brain to be retuned.
Who's doing the tuning? You may want have them check the injector code(s), that has to be correct or it may cause issues also.
If whoever is doing the tuning can't seem to get it figured out, you might want to look into: https://greendieselengineering.com/...m/GDE/Ram-1500-EcoDiesel-Hot-Tune/2_37.action
They offer the "Off-Road" tune which is a full delete but you probably should give them a call to explain the situation. They are a top notch company to deal with and have lots of R&D along with millions real world miles on those EcoDiesel tunes.
T
Thomas46
Hernando, ms
Eco diesel
PPEI did the original work and has it now
Thanks for your info...
T
Thomas46
Hernando, ms
Eco diesel
I got the mid range, 40 horse, tune, Ran great, very little if any smoke. Then the fuel pump implosion and replacement. That’s when the trouble started.
therapywolf
