EDGE Pulsar
Mailey
HELP !!!
I recently removed my pedal commander and upgraded to a edge pulsar.
I've have done the follow;
- disconnected my positive and negative from battery
- removed the tie straps
- disconnected the 2 plugs from board
- removed board and placed pulsar and tightly flushed to board
- put plugs back on properly
- put battery connections back together. After 30 mins
I then started the truck and it has run like ****. The rpm flexuates then the truck shuts off.
Message board says service shifter. Cant go from park to anything without the truck shutting down on it's own.
I remove the pulsar and truck runs perfectly fine.
I yet to contact edge product.
Thanks for your help.
TXCOMT
HELP !!!
Might want to start calling the company that made the product your truck is having an issue with...
TXCOMT
Djoker04
Ram 1500 2015
HEMI
Did you get it fixed? According to your post You missed a step...after putting cable back on you're suppose to set it up.....Don't just start it!!
Unless you did that but you didn't mention it....
rubes7202
PLEASANTON, CA
what is the setup step you refer to. there are none. it should just work fine after install.
meedom
If I was you I would pull it all back apart carefully, disconnecting the battery first of course, and try
it all one more time. It only takes one little contact point somewhere not connecting the way it should
to cause issues. Believe me I know, I've been in the computer\IT industry for 34 years. If it still doesn't
work call the support number on the manual....
Djoker04
Ram 1500 2015
HEMI
I stand corrected you’re right...after installing mine just put it on the setting I wanted and boom done....
rubes7202
PLEASANTON, CA
Just heard back from dealer. PCM is fried.
Sent from my SM-G965U using Tapatalk
MXM34
Caused by the Pulsar? What has their customer service said about this?
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
OUCH....Id love to loose MDS....but why I haven't bought one yet....let us know outcome.
ThunderMug95
North Prince George, VA
I had purchased and installed the Pulsar a month or so ago. Ran great evening after install. The next morning it shut my truck off twice in 30mi. Immediate uninstall and returned for refund.
rubes7202
PLEASANTON, CA
They said it was a defective unit and said they would send a replacement. I said don't bother. I want my money back
Triumphx
I had a edge evolution on my old Cummins that fried my ecu. Edge replaced the ecu, paid for the programming and the tow. Don’t lay down and fight for it!
stevenmicheal
