Sportznut
- Jan 3, 2015
- 589
- 248
- 2019 Laramie
- Hemi 5.7
2019 Laramie 1500 4WD w/air suspension.
After reading a bit on this site and viewing YouTube videos I'm going to give leveling links a try.
I see that Edgy is a forum sponsor so I am leaning this way unless there is a better link out there for some reason? The Edgy appear to be good quality.
I have not read any negatives about any brand links to be quite frank. They look pretty straightforward.
A little worried about how stiff the ride might get, regardless of the brand of link.
I might consider doing the rear instead of the front because I do love my smooth ride.
I read somewhere else that you can lower the rear instead of raise the front with the same links? Supposedly it does not affect the ride quality? Have any of you done that? Results? I'm guessing that will further limit the size of tire I can use?
On first try I am not planning on using anything other than the links.
I don't do any off-roading, very limited and very lightweight towing. Just an occasional run to the dump with my 5 x 10 utility trailer.
Any thoughts or suggestions are welcome.
Thanks in advance.
Thanks in advance.
