Effects on lowering?
drozek
Streamwood, IL
i have been spending too much time on this forum since giving in my 2 week notice at work.
Questions on lowering, does lowering the truck have any pros and/or cons? I don’t want to do anything too crazy but I see too much wheel well on my truck
Tray Burge
On the porch
Pro's if done correctly: will drive like a go cart on rails and stay flat during cornering, way kewel looking too.
Con's if done incorrectly: will drive like ****, bottom out on everything, will be all over the road and feel totally F'd up.
D
drozek
Streamwood, IL
Haha thanks what lowering kit will allow me to keep my stock 20” rims?
Tray Burge
On the porch
2015 has coil springs all the way around doesn't it? Regardless, McCaughey's (spelling?) is who I used, but mine has dropped spindles up front and a flip kit in back with sport shocks all the way around. I had a friend that used McCaughey's (spelling?) for his 4th Gen, all coils springs and his came out great too. Others have used comparable components from other companies with similar results. Use a kit, don't just start chopping off coils!
D
drozek
Streamwood, IL
Thanks time to sink some more money into this truck
Mcginnis
Forney, TX
Get the inez hotrods kit. Best kit if you're wanting lower than a 2/4 drop
abouttobeglue
I saw where belltech has a new 964hkp kit with coilovers for our trucks, its $$ like 1600, looks like it comes with more parts than the spring and shock kits. Cant find any more info on it though
Wicked
Houma, LA
2016 Sport
Pretty sure that’s the 4x4 drop kit.
*Edit: nvm seems to be some new sort of performance handling kit.
RTnoob
Tx
I got the 964HKP on order. I called Belltech to get more info, didn't get much help. Guy said no coilover and the spring rates are higher. For the cost it should come with coilovers but it doesn't say coilovers on belltechs site. I wanted to know how the front height is adjusted if there's no coilovers but he didn't seem to know much. Every site has different info for this kit. He did say I was the first to order it but they're still putting the kits together.
abouttobeglue
Rtnoob, I'm curious if the hkp kit includes anything like the illicit brackets to deal with control arm angle. If you can ask em to send a part sheet for item thanks for the info
circuitguy
Elk Grove, CA
2017 Ram Tradesman Regular Cab
5.7L HEMI
I second that!
RTnoob
Tx
You talking about the rear control arm relocation brackets?
RTnoob
Tx
You can see the rear shocks are double valve and the front single. Everyingthing else is the same as the reg kit.
5317
4762
5553
Panhard relocation
I hope to get it in next weekend.
abouttobeglue
Yeah, didnt know if they had done anything to address s pool me of the issues people have had.so it's just higher grade shocks?
RTnoob
Tx
Yep, front you can adjustable compression, rear compression and rebound. Wish it was a 2/3, I tow to much for a 2/4.
RTnoob
Tx
A little to low in the rear for me. Going to put some GF 2" I have in. Make it a 2/2, kit took about 2 and a half hrs to put in. Not bad
