eibach pro
nekkidhillbilly
hemi
whats everyones view on them vs bilstiens? can score them a bit cheaper and do pretty much same thing.
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
They are apples to apples. Minor variations but eibachs warranty is better and easier to submit. It comes down to height settings the higher you go the stiffer the ride
N
nekkidhillbilly
hemi
im just going to level it so they are less expensive and are just as good ill prob go with those
crazykid1994
If you really want a killer setup with that look into the eibach front springs. They were a night and day difference in my opinion. Can be used on either bilstein or eibach front struts and gain you 2” front lift. I’ve heard people say the eibach fronts feel a tad bit softer over the bilstein as bilstein aims for a more sporty feel where eibach aims for a more plush feel.
N
nekkidhillbilly
hemi
im only looking at 1.5-2 inches at most. not trying to lift it really just nice and level.
crazykid1994
I didn’t say lift the whole truck. I merely mentioned using their front springs to complement the front struts as the springs give you 2” of lift in the front and feel more plush than the stock springs do at the same height. You can purchase front springs alone not as a complete front and rear kit.
N
nekkidhillbilly
hemi
oic. since they are more plush i wonder if they will ride like stock but leveled.
Poncherello
Well, I hope it is all good. I just bought an Eibach Pro Lift Kit & JBA UCA's hoping to get 2&3/4" lift in the front & 1" rear. If I can get that looking to replace my 20X8 Wheels on 33's with 18X9 on 35's.
minotto
italy
Hello , i bought Bilstein 5100 and put front at 0,7" and rear without any spacer , all shocks work with stocks springs but i don't like the ride quality .
I understood that the secret for a better quality still on springs and anyway i decide to buy eibach springs to use in combination with bilstein 5100 .
Wich will be the best option between this :
1 - Bilstein front at 0,7" ( 2nd ring ) with eibach springs 2,25" + Icon/Tuff Springs rear 1,5"
2 - Bilsten 5100 front at 0" ( 1st ring ) with eibach springs 2,25" + Eibach springs rear 1"
If i set bilstein at 0" + 2,25" from front spring and 1" from rear spring my truck looks like perfect leveled but if i want more height 0, 7 " + 2,25" in front i have to choice rear spring with more height like icon 1,5" or tuff 1,5/2" .
In the first case, with 2.25" of lift, I'll be able to keep the stock ucas ?
Currently they don't seem to have too much wear and the ball joints look ok to me.
In the second case with 2.95" I think the ucas zone update is high recommended, right ?
I
