electrical demons
steveklemme
So I have been told that I may have corroded fuse box and that this might cause the issues that my truck has been having..ie truck won't turn over gauges don't work.. anyone have insight to this I hate to keep throwing money at this thing but I really need to get her back on the road.. thanks everyone
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
The OEM IPM box has a open bottom and can get water and mud if heavy off roading (mudding) is done. I understand the replacements have a covered bottom to prevent this. But cannot confirm this. Sometimes a corrode IPM can have jumpers installed to keep them working.
HolyRamBatman
Deep in the Heart of Texas
You will have to open the fuse box and go through it to determine if it's bad.
Clean up what you can. Maybe sand/scrap the terminals off for better connections. Tighten any fuse holders or relay contacts.
If that doesn't work you may have to replace it. Good luck.
mikep345
