DickLowman
Strange issue: I have installed a camera system (Foo Koo) for monitoring views around my towed travel trailer. Cameras are installed on each side of the trailer, allowing continuous split view awareness. Additionally, the system includes trigger wires for each side camera that is supposed to cause the correct side camera to fill the screen when a turn signal is activated. (i.e., when turning right the right camera fills the screen.) The camera system works almost flawlessly, but sometimes (perhaps 10% of the time) the trigger wire function fails - both cameras continue to show in the split screen but the activated side does not fill the screen. It is as if the trigger wire is not getting correct voltage. Moreover, in shop testing, when the system works, both side cameras work, but when one trigger wire does not activate, neither activates. The Foo Koo customer service is outstanding and is trying to help make this right. But I am uncertain if this is a camera issue or an electronic issue in the truck turn signal unit. I would hate to claim defective camera if the problem could be in the truck. The installation was done by a top ranked electrical shop, so I believe that was done correctly. My question: since these new (2022 2500) trucks are controlled with computerized electronics, could that account for the problem? Any ideas?
