Enable rear fade control.
Busman01
Asheville N.C.
2018 Ram 4500 Regular Cab
Truck came with a 5 inch basic radio speaker in each door up front. I upgraded to the 8.4 infotainment unit the truck is wired for rear speakers I installed them I need to enable them. I removed the Gateway module and put a bypass in there and everything worked including the rear speakers the next time I fired the truck up it went back to balance only. What is the permanent fix to keep the rear speakers enabled?
