Engine check light flashing at WOT
jws123
nj
So I ran an Amazon reader on my truck today. Zero codes and vitals look good. Whatever happened was temporary. Going to continue driving this week and see what happens.
It could just be a coil starting to go I had missfires here and there until one of mine gave out also possibly sticky injector wouldnt hurt to run some seafoam in the tank. If you dont hear any engine noise/tapping ect its probably not a cam yet letting the truck sit often is the worst thing you can do especially with newer vehicles. Not to long ago I had someone that bought a tradesman from a auction because it only had 65k on it however it had 9400 engine hours it was used for township they always kept running so it basically was a 220k engine.
2003F350
6.7 CTD
That's always a gamble with Auctions, or buying a truck owned by a government body (or even a construction company). They might be low miles, but there's a STRONG chance that it sat and idled a LOT. And while idling doesn't do a LOT of damage in the short run, a LOT of idling is almost as bad as running the crap out of it.
62Blazer
Midwest
Typically a flashing engine light under those conditions indicates a cylinder misfire event. The flashing light also means that whatever is occurring may be bad and you should stop doing whatever is causing it....in this case if it only happens at WOT you should stop being at WOT if the light starts flashing. I also wouldn't immediately freak out and suspect the engine is getting ready to blow either. In my years of working on cars a cylinder misfire is a very, very common condition and could be as simple as a bad plug, coil, injector, or even a bad tank of gas. Sure, it could indicate a more serious engine issue is starting to happen but always start with the simple things first.
The engine light does not have to be actually on at the time see any old codes, however a cheapo base model code scanner may not be able to see stored codes. The codes stored in the ECM just do not randomly disappear, but will go from active (i.e. engine light on) to stored or historic status that you should be able to view until cleared with a scanner.
In any case, if it happens again and you can see a code I would suspect it will give you a misfire at a specific cylinder. The first thing I would do is a visual inspection of that cylinder and check the connections. The next thing you can do is swapping parts between cylinders (only do 1 at a time!) and see if the misfire follows the part or stays with the cylinder. For example if there is a misfire on cylinder 3 swap the plugs between cylinders 3 and 5 and go drive. If the misfire is now at cylinder 5 you know it's probably the plugs. If the misfire stays at cylinder 3 there is something else wrong. You can swap the coils and injectors around next.
marshrats30
Massachusetts
I have the same issue. The code said #8 cylinder misfire. Took it to the dealer. They replaced the coil pack, injector and manifold. 5k later still have the problem. Mine is 2014 2500, 5.7 hemi with 323k miles. Always serviced regularly including the 100k service 3x. Check engine light is back on and any time I accelerate hard, it blinks. Is the engine toast? How long can I drive it like this. The dealer said baby it and it will last another year.
jws123
nj
At 323k run it til it blows thats alot of miles for any engine then throw a used engine in if the trucks in good shape. Also how the hell did you spend 5k for a manifold and injector? must be more to the story there i assume.
62Blazer
Midwest
To be honest, sounds like they just started throwing random parts at it versus actually doing some basic diagnostics and testing on it.
Riccochet
Somewhere around Charlotte
2020 2500 Laramie Longhorn
Most dealers don't have technicians any more. They have parts chuckers. They slap on whatever the computer/Stellantis tells them to and send the vehicle on it's way. Real technicians are worth their weight in gold as they can do actual diagnostic work. Sure, the computer/scanner gives them valuable data. It's using that data to find the actual problem that these new UTI graduates lack.
62Blazer
Midwest
Agree with you. The only thing I will say that the manufacturer or the scanner is not telling them the first thing to do is start changing parts. The factory diagnostics manual has trouble shooting trees for every code, and the first several items in that tree are always testing power feeds, grounds, reference voltages, resistances, etc.... Only after going through all of those tests and following the diagnostic tree will it point to replacing certain parts that tested bad. But again, your comment about "parts chuckers" is unfortunately common nowadays.
