Engine codes.
Macko88
Illinois
My Ram threw some codes the other day. I pulled the codes also looked up a diagnostic chart. The codes i pulled are
P-0606 Internal Control Processor
P-061A ETC Level 2 Torque Performance
P-014C O2 Sensor Slow Response Rich to lean
P-02E8 Diesel Intake Airflow Position Sensor Circuit Low
Any ideas of where to start with this would be appreciated. First time owner of a diesel.
BossHogg
Navy Badge Law Enforcement
Oakland Township, Michigan
6.7L Cummins
If your diagnostic tool can pull freeze frame data, look for an association with one of the DTCs.
M
Macko88
Illinois
I used the internal diagnostics. I let it sit for awhile attempted the codes again. This time i pulled P-0562 low battery. a friend of mine has diagnostic tools. We are going to try to use later. thank you for the advice!
