Engine Making Fluttering and Vibration Noises
ShawnS604
Vancouver, Canada
Hey, I have a 2017 Ram 1500 with a 5.7L Hemi. Just recently had noticed, everytime I accelerate, the engine (I believe) is making a fluttering noise that last about a few seconds then goes away as I gain momentum. Once I start gaining momentum, around 60km/hr, I feel like there is a vibration noise coming from underneath which last about a few seconds as well. Has anyone else experineced anything like this before ?
Ken226
Washington State
Do these occurrences happen to coincide with the ECO light on the instrument cluster coming on, or going off?
Ken226
Washington State
No, I have that ECO light option turned off for years now.
Having the ECO light turned off only deactivates the light, it does not deactivate the ECO mode or MDS.
I'll rephrase,
If your ECO light were turned on such that you could actually see when your engine enters or exits ECO mode, would there then, be a correlation?
Because what you are describe sounds an awful lot like what happens when the you enter or exit MDS mode.
The PCM temporarily unlocks the torque converter, then the MDS solenoids open and allow oil pressure to collapse the MDS lifters, then the PCM re-locks the torque converter. This occurs on MDS trucks regardless of whether you have the dash indicator turned off or not.
To test this theory, drive in tow/haul mode and see if the situation changes. tow/haul actually deactivates MDS mode.
ShawnS604
ShawnS604
Vancouver, Canada
I'll rephrase,
Ok, I will definitely test this theory to drive in tow/haul mode. If this is the case, would the fix be to change out the MDS solenoids ?
Ken226
Washington State
No. If that is the case, then it is operating normally.
Even though this is likely the normal operation of the MDS system, if it really annoys you enough that you are willing spend some money to fix it, then you'll Need to replace the camshaft with a non-mds cam, replace the lifters with non-mds lifters, and use a tuner to shut off the mds programming.
You'll be wanting something like this:
Do a search on this forum for "MDS Delete" and you'll find alot of reading material.
ShawnS604
ShawnS604
Vancouver, Canada
Thanks for the information, much appreciated.
David H
USA RET
Minneapolis
This will not tell you anything. Tow/haul does not deactivate MDS. Manual selection of gearing is what you want.
crackerjack1957
2014 Sport 1500 CC 4x4
Hemi 5.7...65RFE...4.56
Why would you want to tow with 4 cylinders in tow/haul mode with MDS on???
Think about it..........LoL
David H
USA RET
Minneapolis
Just the messenger. Tow/Haul deactivates MDS on the 6, but not the 5.7 In this video the guy actual demonstrates it on the road as well as how it works with manual gear selection.
crackerjack1957
He doesn't prove it doesn't deactivate on the 8-speed though.....only says it.....he demonstrating with a 6-speed.
I have the 6-speed so I can't prove it.
I remember before my tune the eco light always had to be on before MDS would activate.
In tow/haul mode there was no eco light so no MDS.
Maybe someone with an 8-speed can shed some light on this.
I would think if tow/haul locks out 8th gear there would be no eco light so no MDS.
Find it hard to believe tow/haul would allow the 8-speed to run on 4 cylinders while towing.
David H
USA RET
Minneapolis
Yeah, he is demonstrating with the 6 . I missed that. He is correct about the 8 however.
I have the 8 and tow a 2 place sled trailer. In tow/haul the MDS is very much alive below 65 on a flat stretch or downhill. Half of the 5.7 is more than enough for those situations. To deactivate which I do for faster speeds I have to select gearing manually.
I think the disconnect is the 6 speed acts slightly different from the 8 and we...(I) forget there are a lot of 6 speed trannies out there.
crackerjack1957
In that less than 65 or downhill..... is the eco light on & what gear is it in with MDS on in tow/haul mode?
David H
USA RET
Minneapolis
Yeah, as I recall the Eco light comes and goes like always. Couldn't tell you what gear. Unless I've selected gearing manually, (MDS off) the dash doesn't display what gear it's in...not that I've noticed anyway. I'll play with it some today. See if I can find a gear display in the DIC.
crackerjack1957
Should be able to determine gear by rpm at a set/certain speed
crackerjack1957
I wouldn't know about that. Confirmed with tow/haul selected, Eco comes and goes and MDS shutter does as well. That shutter is not something that bothers me but it is noticeable.
Easy.....set gear in 6th & hold speed at 50 to 60mph or your speed of choice.....check rpm at that speed.
Next drive leave gear select alone while in tow/haul mode and check rpm at the same speed above.
If its the same than tow/haul mode locks out 7-8 gears.
If not the same try 7th gear.........and of course out of tow/haul mode 8th gear can be seen at that set speed with rpm.
Marshall
Sk, Canada
2014 sport
I have not used tow/haul much in this truck, and i have a real hard time feeling it go into eco mode if I am not looking at the light. I have it come on in town quite a bit , lots of slopes.
On the hi way on a good flat road with no head wind ( rare in this country) I have had mine go into eco mode at 120-125 km , normally on at 115km if conditions are right,
I never feel it , and can't hear it if windows are up, ears are old as well.
Also, how many miles, have you checked for exhaust gasket leak? That could sound like a flutter.
hi miles maybe time for trans fluid change and spark plugs, I may have missed the mileage, if you stated it.
ShawnS604
ShawnS604
Vancouver, Canada
It has about 141k kms. Did get checked for exhaust leaks and didn't appear to show any. Did also have all 16 spark plugs changed recently too. Haven't done a trans fluid service yet, should get on that.
