CamoX413
I'm having a problem where my engine isn't warming up to normal operating temperature. This all started after I changed my plenum gasket and added a Hughes plate.
Since I had everything taken apart I decided it was a good time to change a few parts so I installed a new duralast thermostat and coolant temperature sensor. Ever since then my gas mileage is in the garbage at 9mpg and my engine temp gauge only read about 160-170 at it's highest.
Anyone know how to determine which one is likely the culprit so that I don't have to tear everything apart and start guessing?
