Engine question
Geer hed
PA
4.7L
I have an 02 Ram 1500 sport. It has the 4.7L engine in it, with auto trans, and 4 wheel drive.
I need to replace the engine. The cost of a new one is not even close to being affordable for me right now. So I am looking at used engines. I have found a couple but my question is, some of them are out of a Durango, or a Dakota. The only thing I see listed is that the 8th digit of the vin is an -N-.
Is there any thing else that I need to go by to make sure the engines are the same ?
I don't want and can't afford to make that kind of a purchase mistake, and especially this time of year.
I really like the truck, and it's my first Dodge so I'm not up to speed with Dodge's different engines.
Any help you guys can give would be greatly appreciated.
Thank you and Happy Thanksgiving.
ST-8
The big thing is they change the tone ring tooth count somewhere around that year you have so you need to see what yours is, dakotas an Durango’s will be interchangeable for you depending on the tone ring
HemiLonestar
Navy Badge Coast Guard
MD
Absolutely has to have the same tooth count on the crank tone wheel. If you try to install a different count you'll be lucky IF it starts at all. Only way to change it is to pull the crankshaft.
Geer hed
Geer hed
PA
4.7L
OK I'm guessing then that is what I have seen them reference the vin number correct ?
I have seen them reference the 8th digit as -N-, so if I get another one that has the same digit I should be good to go, or is there another way to tell before I pull the engine?
SDOTR1
bloomfield nj
5.7 hemi v8
good evening i have a question would anybody no why when you put a new starter in the 07 ram 2500 I'm just getting a click i turn the fly wheel to make sure its free i put the truck on jumper cables with another truck but can't get it to start do anyone have inf of this issue
Nick_rp
I=V/R
puyallup, wa
5.7 Sport
jumper cables wont start a vehicle with a dead battery right away anymore. get a full charge and try it again
edit: actually could be wrong since its a 2007, make sure battery is fully charged anyway
Geer hed
Geer hed
PA
4.7L
I would start by load testing the battery to make sure that's not the issue, but
If the truck started fine before the starter went bad, it could be a bad connection on the cable going to the starter, the cable itself could also be bad, also they ground through the starter housing and bell housing so if that's dirty it can cause issues, and I have seen brand new bad starters themselves right out of the box.
stevenmicheal
