BabyRayD100
originally had an issue with piston not fitting but after lubing up the rod it moved freely on the center pin now with all the piston in and rod caps finger tight i go to torque the caps and now the crank wont spin at all even with a long break bar
I believe my issue is the rod cap direction? i made sure to keep all the caps and rods together but did not pay attention to with direction they should be installed back on
