crazzywolfie
- Joined
- Apr 6, 2013
- Posts
- 16,646
- Reaction score
- 3,430
- Location
- under the truck
- Ram Year
- 81 93
- Engine
- 5.2
the 318 engine in my 93 ramcharger is not running right. i know this it the 2nd gen section but they only use the 318 magnum in the 1st gen body for 2 years before they completely changed body style plus i know the 1st gen section can be kind of dead.
anyway onto the issue. engine was running rough. no power and lots of stuttering and shaking. i check for codes and got code 32 so i replaced the egr transducer with some older egr transducer parts i had kicking around. that made engine run fine for a couple of days and then it started having the same issues again. i managed to find another transducer and put it on but there seems to be no change. i have reset the computer and checked for codes but nothing at all is coming up even when it is running rough. no i have not repaired my plenum yet but i got a pretty good exhaust leak that should make a clogged cat not such an issue. o2 sensor is less than 6 months old. hoping to fix this cheap to make my sister not feel as bad since she has been driving it lately.
here is some video footage i got of it today. i don't know if you can really hear how poorly it is running or not. my laptop is limited volume wise so i find it pretty hard to hear how rough it is running.
My rc not running right - YouTube
