Engine shuts down at red lights.
allyn731
virginia beach, virginia
I need some assistance, doing some research on why my 2011 RAM stalls out on me at stop lights. Its random and I wanted to know if anyone has run into this issue and what they did to fix it. Thank you
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
You may want to check this out, it was the first thing that i found online
a dirty or failing idle air control valve causing your engine idle to fluctuate. ... When this happens, the job of the idle air control valve is to bring this deceleration down to a slow and smooth idle rather than suddenly cutting off the fuel supply causing the motor to die
I think that your throttle body is dirty
AJNY
Middletown, NY
My friend had a 2014 with the same problem. The dealer couldn’t figure it out. They offered him a trade and he took the deal. He spent a lot of money without results.
huntergreen
Marine Corps Navy Badge
When was the last time the spark plugs were changed.
Daw14
South Florida
Any of the above may be the cause, please be sure to share the fix so it can be passed on.
Mister Luck
cassis tutissima virtus
WEST COAST
5.7 V8
Brake booster vacuum hose leaks
Daw14 is correct it could be a number of things not shown on a scan tool
Fast69Mopar
You didn't say which motor is in your 2011 RAM so it's a little hard to give advice.
Is it a 3.7L V6, a 4.7L V8 or the 5.7L HEMI?
stevenmicheal
