Engine stand
New2dodge
4.7L
So just pulled my motor. First time ever pulling one and can’t get it on the engine stand. Measuring I would need 6” bolts to hold it on. Is this normal or am I doing something really wrong?
Green_Manalishi
Looks to me like you need to remove the flywheel and converter. 6" bolts aren't the solution.
Daw14
South Florida
This ^^^^^ , finish removing the flywheel and torque converter. That will make it closer.
20IndyRam
Guest
Extreme Northern Indiana (Michiana)
EcoDiesel
Agree with the previous posts...
In addition, buy grade at least grade 5 (preferably grade 8) bolts. Depending on whether you have intake and heads installed, you will have 500+lbs on that stand. Do not trust that to hardware store soft (grade 2 or less) bolts.
This is a big fast forward, but - I personally would never try torquing heads on an engine stand. I've never tried a modern Hemi with AL heads. I have tried the older cast SB and BB heads on 60's, and 70's vehicles. You can't get a good torque with the springiness of the engine stand while it's chasing you around the shop. Torque them to a low/equal value on the stand and then finish in the vehicle.
N
New2dodge
4.7L
Thank y’all for the advice. I’ll be removing it today. Also will be getting some grade 8 bolts.
a17ram
