Engine struggles to turn over
14RamMan
Ive been having some trouble with my truck starting over the last few months. When I hop in the drivers seat and immediately try to turn the engine on, it turns strong, but doesnt catch (engine seems to not be getting any fuel). However, if i turn the ignition to the on position, without starting the engine for 2-3 seconds, then try to turn the engine over, it starts immediately. Is there some kind of check valve in the fuel line that might be bad?
huntergreen
Marine Corps Navy Badge
Still running original battery ?
BOWERSFJ
Uniontown OH
I always turn the fob one click, wait a couple seconds, then start it ... Always have ... Just gives the fuel pump a few seconds to get stuff where it needs to be
14RamMan
14RamMan
Its a 1 year old battery. Im concerned about this because its never acted this way since I bought it new in 2014. Leads me to believe something may be going bad. Is there a check valve or something common (hopefully easy/inexpensive) to repair?
Marine Les
Show Low az
5.9 cummins/3.6 Pentastar
I think there is a check valve in the fuel system and it may be leaking fuel back to the tank after sitting a while. If you turn the ignition on and wait the pump has time to run fuel back up to the injectors and I would do this to save on the starter. I do not know where the valve is but most likely in the tank making a repair costly.
14RamMan
14RamMan
Thats sort of what Im thinking (but hoping it isnt)
