Engine surges
Jdoc
Princeton, NC 27569
I wondering if anyone has had an issue with engine surges or Rpm spikes?
My 2014 1500 has been doing this for sometime now. I really dont see the rpms physically go up/ dn. But I can hear it. Truck has approx. 153,000.
I have had the air induction cleaning less than yr. Ago. I dont have a chk engine light or any other things going on. Help!
Elevated 2013
Huntley, IL
So you don’t see the tachometer on the dash move at all when the engine is surging? When does the engine surge? At idle, certain speeds, or only when in Park??
McBroom
Denison Tx
Hemi 6.4L
Might need to run a fuel system cleaner through it. Its possible it's a dirty/clogged injector
Blue Mule
Jdoc
Jdoc
Princeton, NC 27569
Elevated 2013...I only see it move sometimes. But it's minimal like 1 or 2 hundred rpms. Is all. I hear mainly like just cruising at 55 or up but I do hear ot at lower speeds.
Elevated 2013
Huntley, IL
I would start with McBroom’s suggestion first and try running a bottle of Seafoam in your next tank of gas and maybe go up a level of gas at the gas station for 1 tank and see if that helps. Maybe also clean your throttle body really good with some carb cleaner. See what happens from there since it’s such a small variation/surge.
Jdoc
Jdoc
Princeton, NC 27569
Yea I use seafoam on a regular basis. Time before last I used a high milage fuel sys. Cleaner. Plus the throttle body has been cleaned by dealer.
I have had a few low speed shudders. Which sounds like something with torque converter. Not sure if tranny would cause the up/ dn revs I'm experiencing due to shudder at times.
crackerjack1957
2014 Sport 1500 CC 4x4
Hemi 5.7...65RFE...4.56
If it's a 65RFE trans probably the cause.
Maybe time for new filter/fluid.
Jdoc
Jdoc
Princeton, NC 27569
It's an 8 speed...8Hp70 I have changed fluid but it's been at 116 thousand. Got 153 now.
Lyle Longboat
2011 Ram 1500 5.7 Sport CC
Moosonee, ON, CANADA
Same
Problems on my 2011 ram 1500. RPMs spiking at idle, shuddering, and then the trans finally blew. My fluid was already burnt in 2018. But I had been using lucus transmission additive all Tia time since 2018 and it finally blew. Anyways these symptoms probably have something to do with TC and should be checked before things get Into the 1000’s to fix, like me!
RamCares
n/a
n/a
Hello Jdoc,
We are certainly sorry to hear about your recent concern. If you are unable to remedy this concern with the assistance of fellow forum members, I kindly suggest connecting with your local dealer. If you decide to go this route, and you are in need of any assistance with that process, please feel free to send us a private message.
Laura
RamCares
Wallyb4
Retired EWC(SW/AW) 1983-2003
Virginia Beach
5.7L
Might want to try the IAC and the TPS. I had a 2002 Durango with a 5.9 and that is what was causing mine. I know different types of veh but the basics are the same.
RamCares
n/a
n/a
Hello @Rodney Hamilton,
We're sorry to hear that you are experiencing these concerns in regard to your vehicle's engine. Should you elect to address this in the form of a dealer appointment we would like to offer up our assistance as well! To get started, send a private message our way.
Hannah
Ram Cares
savage_46
Alaska
6.4 swapped
I recently had a customer demonstrate his low speed surge to me. Replaced the throttle body even though all data looked good. The only questionable thing I saw was TPS voltage spike which looked like a self test on the graph. Also check for purge solenoid or intake manifold leaks
stevenmicheal
