Enter-N-GO
Edward Urbany
Massachusetts
I have a Big Horn that does not have Keyless Enter-N-Go but i do have remote start. Is it possible to add this feature or is there an aftermarket product that enables passive entry?
#firstworldproblem - I don't want to use my Keyfob every time i unlock or lock my truck.
Duane Pipes
FL
Was hoping to find info on this also. The link provided is specifically for push button start
Jimmy07
Well, it’s for push button start AND passive entry (keyless enter n go). I’m not sure about aftermarket, but you can add factory push button start without adding passive entry, but it can’t be done the other way around.
Duane Pipes
FL
Copy that. Wish I paid more attention at the dealership. I did ask about lock/unlock features but I made peace with it too easy and quickly
Atcer2018
Virginia
Even if you could add passive entry without push button start (which you can’t) the push button start is only an additional $100 in parts and is the easiest part of the keyless n go retrofit. A $70 switch, two $10 antenna, two $2 connectors and a few extra feet of wire. There is a whole section on this forum about adding passive entry, push button start and it’s very well written and highly supported. Added it to my Big Horn without any major glitches and it works flawlessly.
