Teligence
- Feb 11, 2017
- 26
- 0
- 2003
- Hemi 5.7
I have an active P2181 with a pending P0128. No change in either status since the Fault light lit.
1. I replaced the thermostat with a new tested one that maintains the prescribed temp (195F).
2. I've replaced the ECT sensor with a new one.
3. I've fully drained (including the block), flushed, refilled, and have run/driven it at NOT (Normal Operating Temperature) for over 40 minutes.
4. The displayed temperature on the dash shows just slightly under the center mark - about where I'd expect for a 195F t-stat. My bluetooth scanner shows that when idling, the temp settles at 195.8F, so, the ECT is sending an acceptable temp to the PCM.
5. After several warmups/cooldowns, the coolant level is still good (just above the cold fill line after the engine has cooled to ambient.
So, I'm at a loss at this point. Any suggestions other than taking it to a shop where they'll probably want to do exactly what I've already done?
