HPjunkie
Stranded again. 1st time 4k now 42k. 1st time no boost. Now this.basically dont know what the problem.
MR DRI1:
DRIVEABILITY CONCERNS
ENGINE PERFORMANCE CONCERN
VEHICLE DIES 30 SECONDS AFTER STARTUP
Caused by
FAULT CODES P016F CLOSED LOOP FUEL PRESSURE
CONTROL AT LIMIT- PRESSURE TOO LOW, P0087 FUEL
PRESSURE TOO LOW. REMOVE AND INSPECT FUEL FILTER.
CHECK LIFT PUMP FUEL PRESSURE. PRESSURE IS 70 PSI.
SPEC IS 65- 110. PERFORM CYL BALANCE TEST.
INJECTORS WITHIN RANGE. FUEL PRESSURE FLUCTUATING
EXCESSIVELY. REPLACE FUEL FILTER. TEST DRIVE FOR
15 MILES. OK AT THIS TIME.
Work performed by Dale Parker(768)
TEST DROVE ANOTHER 8 MILES NO FAULT
#3 - MR RRT:
RAPID RESPONSE TRANSMITTAL
RRT 1
19-011: 2017 DS 3.0L POWERTRAIN CONTROL MODULE
UPDATES **
Corrected by 181904JQ:
PERFORM RRT 19-011
18-19-04-JQ 0.3
#4 - JE FUEL7:
REPLACE FUEL FILTER
Installed 68235275AA :FILTER KI: FUEL/WATER SE
Sent from my SM-G965U using Tapatalk
MR DRI1:
Caused by
#3 - MR RRT:
RRT 1
UPDATES **
PERFORM RRT 19-011
18-19-04-JQ 0.3
#4 - JE FUEL7:
REPLACE FUEL FILTER
