EVAP code and broken pump
56PW17
Pa
Can anyone tell me the name or part number of this part?
44F257E9-7D93-4F05-B70A-05C47E256C5B.jpeg 9E0E326B-8780-4E9D-A89E-CEB6B32AF9A8.jpeg 9164970E-77A2-4ED4-ACE7-F38A14AAF20D.jpeg 2017 2500 6.4L.
I had a battery spill in the bed of my truck. Thought i got to it in time but my truck threw a code this AM. I knew it had to do with the spill so i connected my scan tool. Picked up the P0455 code. Cleaned my bed and under carriage. Let it dry and got under the truck.
Found a hose with a broken connection. Look like it goes to the fuel pump? Was able to take a few pictures. Has anyone dealt with this repair before? It is Definitely a hard place to get to with the tank in place. Sure i would have to drop the tank. Not sure if I should attempt this myself but don't want to spend $500 or more at the dealership either. Wondering if anyone has experience with this? This is the fuel pump right? Thanks for the help guys.
Trying to find a fuel tank schematic, doesn’t look like it is the pump actually but I am not knowledgeable on this. any help is greatly appreciated !!
Dark Knight 500
Alberta
What’s pictured is the rollover valve I believe. Only serviced with the tank.
56PW17
56PW17
Pa
When i search roll over valve i see a cap with one hose coming out of it. The cap that i broke likes like it has three connection points?
madtrucker2016
New York
check with the dealer if they just sell that cap. Looks like it twist off cap ,maybe dealer can tell you if so. But that would suck if you had to go for a whole gas tank because of that little plastic part breaking off. Today's parts are made to break so you have to buy new, well good luck and hope you can just buy the cap. Also last time I was at my dealer I was in the shop by the overhead door they had a pile of gas tanks they were chucking out maybe you can take a part from one if your dealer has them laying around, its a thought only
56PW17
56PW17
Pa
I like that thought lol. Wonder if my dealer would let me? Looking to get this solved asap. Feel so stupid for letting the battery tip over.
56PW17
56PW17
Pa
This isn't looking good. Looks like the valve is cracked.
Tach_tech
5.7L HEMI
Unfortunately that is only serviced with the tank.
