EVAP Purge Valve Replacement
RAMTRPR
"Enjoy The Little Things"
Brentwood, CA
So I have a couple engine codes for evap failure and small evap leak.
I checked out the EVAP purge valve and only one hose is hooked up. Where is the bottom vacuum hose supposed to go?
Tach_tech
5.7L HEMI
The outlet of the purge solenoid will go to the intake manifold. The inlet of the purge solenoid comes from the evap canister.
RAMTRPR
RAMTRPR
Brentwood, CA
Awesome. I found the connection sitting down below. I connected it back but it does not connect very tight. Might have to replace the hose unless I can replace just the end.
Thanks for the help.
Tach_tech
5.7L HEMI
If it was the bottom hose, it’s just a
Quick connect fitting, they’re not super tight feeling but they deal just fine. As long as you can pull it off without depressing the release tab it’s fine.
