EVIC in Daytime mode flickering
tzmndvl308
az
Evic came out of a 2017 with 14,000 miles on it. Been working great for 8,000 miles, now the screen flickers light to dim when the headlight are off. Tried the loose fuse and connection checks.
Only seems to happen 70 degrees or lower. Any recommendations of someone that can repair this? (not the dealer) Only happens in full brightness. Everything else works great.
SitKneelBend
St. Louis
3.6 Pentastar
Sounds like maybe a cold solder joint. If you are somewhat handy and have a heat gun you can open it up and try to reflow the solder (carefully and not to close/hot).
T
tzmndvl308
az
Pulled it apart. Did not remove the gauge needles, so could only see the back of the board. Everything looks solid. Nothing loose.
SitKneelBend
St. Louis
3.6 Pentastar
I know, sometimes its not evident to the eye (if its even a problem). The temperature thing is what triggered me to say that BUT it's also possible for that to happen at the harness too.
T
tzmndvl308
az
Possible to remove the gauge needles and re install them? (to see the other side of the board)
SitKneelBend
St. Louis
3.6 Pentastar
That I don't know but I know someone did a tear down write up. If I can find it I'll post it here.
Mister Luck
cassis tutissima virtus
WEST COAST
5.7 V8
When the running lights/ headlamps are on does the brightness change and can you adjust the brightness with the potentiometer dial ?
T
tzmndvl308
az
Night time, it adjusts dimmer without problems. Click it to "parade", and it flashes. Daytime... Only bright (and flashing) The original 3.5 cluster works fine.
Mister Luck
WEST COAST
5.7 V8
Sounds like when HID’s aren’t registered with CAN bus
Was the harness compatible ? Maybe see if there is registration conflict between the years ?
T
tzmndvl308
az
Truck is a 2019 1500 Express
Donor vehicle was a 2017 Bighorn
Worked perfect for 8,000 miles.
Mister Luck
WEST COAST
5.7 V8
This member has posted a similar problem and I suggested a possible GPS device attached to the OBD port for power could be creating interference
(not flickering though)
I had a similar issue because of a GPS unit that I had knowledge of but didn’t realize it was tapped at my OBD port for power.
