My ‘21 2500 Hemi w/4.10’s pulling my 5W got 9-ish overall on a cross country trip this summer. Long climbs on I90 with head or cross winds reduced it to 7. I pull about 10-10.5k lbs loaded and rarely exceed 65mph.
mine are all hand calculated. just wondering if you get better MPG towing a 5th wheel as opposed to a TT? no idea how but seems consistent that the 5th wheel posters show better numbers than bumper pulls doI just fill the tank. As long as there is not a significant drop consistently, mpg is just a minor thing, in the grand scheme. Lie o meter, hand calc, I don’t bother. Lie o meter is fine to me.
Assume you mean Cummins. I never have been able to make the $$$ worth the Cummins for my uses.How many more MPGs did your cummins powered trucks get?
Considering other costs associated with owning a diesel, such as higher cost per gallon for fuel, are you really loosing money with the new 6.4L hemi?
The diesel is like the big brawny guy in the bar who just chills because he knows he has nothing to prove.Gas vs diesel has been debated in terms of dollars and cents ad nauseum so I won’t go there. My experience has been the quality of the tow was better in the diesel. Acceleration both on ramp and passing was quicker and the engine / transmission seemed to be taking it in stride. Listening to a gasser scream all day just got on my nerves. Accelerating felt like I was pushing it to its limits. Just a very annoying experience for me. I like my spark plugless ride for towing.
The diesel is like the big brawny guy in the bar who just chills because he knows he has nothing to prove. The gasser is like the little guy with the Napoleon complex running around like a 5 year old on too much sugar trying to prove himself.
My checkbook, my choice. Towing is much more enjoyable with a diesel and exhaust brake. Passing, merging, climbing passes is much better as well.......and quieter. I’ll throw you a tow line as I pass you at 10,000 feet. Keep turning up the radio to drown out your screaming hemi.The diesel is like the big brawny guy in the bar who just chills because he knows he has nothing to prove.
Diesel owner = Small *****?
Gasser owner = Sit to urinate?The diesel is like the big brawny guy in the bar who just chills because he knows he has nothing to prove.
My 6.4 with 4.10's tow the Colorado passes very well. Not saying as well as the $10,000 diesel but very well all the same. 50 gallon factory tank gives me about 500 mile range while moving about 16000 gross. 800 mile range empty.My checkbook, my choice. Towing is much more enjoyable with a diesel and exhaust brake. Passing, merging, climbing passes is much better as well.......and quieter. I’ll throw you a tow line as I pass you at 10,000 feet. Keep turning up the radio to drown out your screaming hemi.
Each has its pros and cons. As long as you’re ok with your choice, that’s what matters. I like that blue, by the way.My 6.4 with 4.10's tow the Colorado passes very well. Not saying as well as the $10,000 diesel but very well all the same. 50 gallon factory tank gives me about 500 mile range while moving about 16000 gross. 800 mile range empty.
Thanks.Each has its pros and cons. As long as you’re ok with your choice, that’s what matters. I like that blue, by the way.
My feeling is that a 5W is a bit more stable to pull and that may affect mileage. I found there was a huge difference between towing at 62-65 mph rather than 70. On flat terrain I could drop to 2000 rpm at the lower speeds but higher speed was generally 2200-2500 rpm.So seems like across the board those quoting MPG towing a 5th wheel are about 2 MPG better than towing a bumper pull? As noted by the last posted he says 9 MPG towing a 10,000lb 5th wheel. My son has towed his 8100lb TT all over the country (9000 miles) and never got better than about 8.5. I tow my 9000lb boat and get about 8.5. I towed my step-sons 9300lb bumper pull TT and got 8 MPG. Not just the posted above but I have read numerous responses saying they get 10 MPG towing their 5th wheel that is heavier than anything I have towed and can't get near their MPG and that is with 2 different 2500 6.4's?
EDIT: these numbers are all hand calculated
There is your "problem" my 6.4 had garb MPG until about 8k miles, then i started seeing major improvements. I see 17 MPG hwy 75 mph on 35's. When towing, ill max out around 13-14k# and ill get between 8-10 mpg, hills n all. California has a lot of hills and mountains.I have 1400 miles on the truck. Everything is stock.
Did you recalibrate your speedometer for the 35s?There is your "problem" my 6.4 had garb MPG until about 8k miles, then i started seeing major improvements. I see 17 MPG hwy 75 mph on 35's. When towing, ill max out around 13-14k# and ill get between 8-10 mpg, hills n all. California has a lot of hills and mountains.
All on 87 octane
now that is funnyGasser owner = Sit to urinate?
