Excited!
2nazt
VA
2012 1500 Big Horn
Well I jumped on a good deal 4wheelparts was offering and my 3" PA Body Lift is on the way and an Air Lift 1000 kit! I'm excited even if it won't be installed till middle of next year or a little sooner because I'm on deployment. Still need the Bilstein's front and rear, and I'm doing a 1.5" TGC Spacer in the rear to keep a little rake without having to lower the front down at all, for towing and I like a little rake. Also plan on going with either 18 or 20" Fuel Throttle's on some Cooper STT's 35's for now, till I do some gear's and add the 4" RCX on to what I will have. Just need to figure out the backspacing and offset, that stuff always confuses me, just is greek to me. Just was excited and wanted to share!
triangleman29
CO
Congrats! That will look good when you get it all installed!
Be safe where ever you are!
Wandell
Cummins 6.7
Sounds good! Don't forget to post some pics when you get it installed.
mattman_13
:) I jumped on the pa bodylift from them as well. I've been away working and CAN'T wait to get home to get it all done. Ill have similar to the set up your speaking of except with stock rims ( I really like chrome clads) lol.
Thanks for your service, I'll be looking forward to pics!
TXKID
Houston, TX
Good choice, have one installed on my truck and its never given me problems
2nazt
2nazt
VA
2012 1500 Big Horn
Thanks for the support guys! And there will be before during and after pics, the install will happen at my brothers shop he rents he does car work and stuff on the side, so some family time with a few beers and catching up after a year gone will be awesome plus hooking up the truck, there will be the Corsa DB exhaust install and making the tips fit the bumper, and all the other work, plus intake and maybe throttle body. Will be a huge transformation all at once and maybe by then the tuner will be out, LOL! Just had to share my excitement!
TXKID
Houston, TX
You're gonna have a hard time fitting those tips in the cutouts with that bl. I had to use smaller tips so they wouldn't hit the relocation bracket
2nazt
2nazt
VA
2012 1500 Big Horn
Thanks for the heads up!, do you photo's in a post somewhere of your set up?
TXKID
Houston, TX
Look up Fab Four bumpers in the thread section it might show it
Edit: they don't show my tips yet, I had them installed at a later time
mattman_13
txkid. Take some pics please. As im doing the bodylift next week. Some have cut the brackets. Im not down with it.
fastNugly
Toronto, ON
2012 Dodge Ram Sport CC
Cutting those relocation brackets and welding for strength will allow you to keep those large tips tucked ;)
2nazt
2nazt
VA
2012 1500 Big Horn
I will be able to figure it out as I am a welder and fabricator :)
TXKID
Houston, TX
I tried to take some pics but its much too bright outside so ill try later. This was the best I got though
fastNugly
Toronto, ON
You're cutting about a 1" triangle
Welding the seem will give it the strength.
Plus there is still another bolt or two holding the bracket.
Very simple. Especially if you're a welder.
mattman_13
Im no welder or fabricator and have VERY little confidence it the talent thats available locally. Sort of looked like you all cut out a hole that holds the bumper in its original position? Id be fine to just paint it black and have the tips a little further down or run smaller tips
What size did you use txkid?
stevenmicheal
