nomercy346
So my truck started ticking with around 48k mi, switched from Amsoil SS 5w30 to Redline 5w30, been running the stuff for a little over 500 mi now and it didn't get any better, if anything sometimes it's worse.
So I'm starting to think it it's may be the common snapped manifold bolts, cause it sounds more like an exhaust leak to me but in the end, its hard to tell, might need someone to put rags against the pipes and listen upfront myself.
Only reason I ruled out the exhaust at first was everyone says the heatshields will be loose and mine are pretty tight. Did anyone have the manifold leak without having the heatshield coming loose?
