Exhaust Manifolds | Warped
Flatblack79
Georgia
Cant believe i missed this thread when i had to do mine a few years ago. I used a belt sander and have had no issues since.
Heres a video for anyone that may find it useful.
El_Dude
Spring, TX
2019 Classic SLT
I kinda wished I machined mine instead of getting the Kooks. Woulda saved so much money. Oh well, all is well.
chrisbh17
Question about the belt sander/Remflex/ARP bolts fix - if I use ARP bolts do I lose the heat shields? Do they make a double-ended bolt like stock?
Or am I better off using stock bolts/studs so I can keep the heat shield?
Thanks!
Dodge 1500 4X4
Rochester, NY
I find that using the factory bolts, did the best for me to reuse the factory heat shields, I got mine from RockAuto, and for sure the Remflex gaskets.
mdc1990zr1
Conshohocken, PA
You know, I've been thinking this through for a long time. It seems that the bolts that tend to break are the ones holding the heat shields on. I know that the manifolds tend to warp, and I have gotten a "seasoned" set of used manifolds and had them planed flat at a machine shop and am waiting to put them on my truck with the Remflex gaskets. But, I'm thinking that I am going to remove my heat shield nuts and heat shield. The logic being that maybe the second nut securing the heat shield is making these four bolts too rigid and not allowing them to expand and contract as the other bolts which are less prone to breaking, therefore leading to the broken bolts of the heat shield.
EdGs
FL
I used Everbuilt hardware from Amazon, with Fel-Pro gaskets from RockAuto (didn't know much about Remflex gaslets when I ordered)
That said, I am about 70k past the change and still good. I wish I had spent a little longer on the belt sander as I didn't get them all the way flat, but all is well so far.
It does seem once the manifolds are heat cycled and fixed, they stay good. I kinda think the MDS is what causes them to go wonky from new.
The only other thing would be is if the manifolds werent normalized (not familiar with cast iron processes, though) when made, and if that were the case, it would mean that it wasn't done on a hell of a lot of parts.
HEMIMANN
Minneapolis, MN
2017 2500 Laramie Crew Cab
6.4L HEMI
Yeah, I'm between a rock and a hard place what to do. Getting mighty creaky to do this myself, my sons aren't around much anymore.
And my exhaust guy won't machine them, just buys that new design that breaks instead of the bolts. But man, can I ever hear that cold start exhaust tick on the right bank with hearing aids. Maybe I should just turn them off until the engine warms and ignore it.
EdGs
FL
It really wasn't hard to get them out, and the passenger side is definitely easier.
I was lucky because mine were broken off under the head of the bolt, flush with the exhaust manifold, so I had a stub sticking out.
Do you know if yours is broken off flush with the cylinder head or with the exhaust manifold?
HEMIMANN
Minneapolis, MN
6.4L HEMI
Yeah, I know. It's always easy for everyone but me. I'm not biting.
I haven't looked. Temp just dropped to the 20's (F) with howling winds and snow. But I can sure hear it, only from right front bank and only at cold start. Classic manifold exhaust leak symptom from a known leaker.
I'm not doing anything unless and until weather improves someday.
EdGs
FL
If you get a chance, reach in through the wheel well and feel the corners of the heat shield.
If they are loose and (on the back side of the loose corner) you only feel what appears to be the thickness of the bolt head, you likely have a stub sticking out. ALOT easier to remove.
But, if you can feel the body of the bolt attached to the loose corner of the shield, the bolt is likely broken flush with the cylinder head.
I drove with mine being broke for at least 40K miles, fwiw.
Come on down to SW Florida!
PowersOf12
So, my truck is now making the loud ticking on cold start and gone within 1 mile from my home. I already had the manifold bolts replaced at 130K and the lifter/cams replaced at 155K. My gut says a manifold bolt is broken again but the heat shields don't budge when I tug on them. Can the middle bolts break and get stuck somehow? Although I have the lifetime warranty, they will not look and guess at issues without charging me if they don't find anything.
