Here In ms we don’t currently have any emissions or smog test so was wandering if maybe changing my own cat to a high flow cat or maybe even like a flowmaster cat then putting on one of the mufflers you suggested would that help because I was told that I can’t make my truck any louder with out doing away with my cats and I don’t want it so loud u can’t think but I would like it to be louder than what it is now
Well without knowing what flowmaster you have it's hard to answer that 100% positive but if it's not a 10 series (about the size of a closed fist lol) then you absolutely can make it louder without touching the cats. Other things can make it a bit louder is shortening the tailpipe if yours exits out the back of the bed then shortening that to exit somewhere like what the guy above suggested in front of the rear wheel or whatever will add some DB. High flow cats do definitely make more noise as well. I have to put my factory cats on to pass emissions and when I do that it gets significantly quieter. But there is a chance of throwing 02 codes, but maybe not some people dont have any issue some do.
I've never heard of what the guy above has but it sounds like a nice system if it's a full stainless cat back, worth hitting YouTube seeing If you can find a video or two.
Before I swapped to long tubes i had the factory manifolds, cut out the resonators, factory cats then straight into the 10 series flowmaster and just a 6" turn down and it was super loud for basically just being a muffler swap, louder than any other muffler swapped ram I've heard. If your a princess who can't take "drone" which is simply a loud high DB exhaust then you won't want a 10 series lol you will hear it all the time in your cab, then I'd say check out carven or a flowmaster super 44. Those are still fairly loud mufflers but with smoother tones and a lower DB so wont be rappin in the cab as much.
Also for sure check out that system the member mentioned above it sounds like it's a nice setup.
Definitely hit YouTube before pulling the trigger on one though I'm sure you can find sound videos of dang near every muffler available
