Exhaust Question
lmeavtitn
Omaha NE
2015 Ram Rebel
I am wanting to put an exhaust on my 03 1500 Hemi. I have been looking around and all I can find are 2.5" exhaust kits. I am pretty sure that the Hemi comes with a 3" exhaust. I don't have much knowledge on exhaust systems but wouldn't that cut down on exhaust flow, thus taking performance away?
TheSatinPumpkin
Robles Junction/Three Points AZ
2004 Dodge Ram
5.7L
Stock manifolds then its 2.25" or 2.5" to the Y then 3" single. So yep 3" to the muffler then single 3" out or duals 2.5" out. This is assuming you want to stick with a Y setup.
MADDOG
Living in a Firepit
You'll be OK. Stock is 2.5" into the muffler so you won't be losing any thing. You can use an adapter to up the outlet to 3" if you want. Or, just put a 3" tip on the end with an adapter.
truckin151
2013 sport
Stock is 3in from the Y to the muffler, SI/SO is 3in out, SI/DO is 2.5in.
NWRQC
Or save some coin and just replace the restrictive muffler and call it a day. Days end you will have the same result but with more money to spend else where.
stevenmicheal
