Exhaust Tips
BlackedOutHemi
DFW, Texas
2012 & 2012
5.7L HEMI & 6.7L Cummins
So, my truck has come down to its last bit of chrome left, the tips on the exhaust. Like the rest of the truck, I would like those to be black, my plan is to remove the bumper, tape off the truck to keep away stray paint, and spray paint them with high heat-resistant automotive paint.
My question is, I know I need to clean them first, but what is the best way to prep them for paint? Do I need to sand them, primer, and then paint?
txbass06
NE Texas
5.9 Magnum
I'd scuff up the surface so the paint will have something to hold on to, then use primer or adhesion promoter, then shoot it with the black
Sent from my iPhone 4 using Tapatalk
sullivan
Houston, Texas
If you can, look for a "ultra" high heat paint. I would just clean the tips tape off the truck and use a green scotch bright pad to scuff the tips, and spray them black. Remember, if you use a primer it has to be ultra high heat as well.
txbass06
NE Texas
5.9 Magnum
Duplicolor makes an engine enamel that's good up to 500 degrees and VHT has a header paint that's good up to 2000
BMRbrnSNRbrd
Norman, OK
2010 Dodge Ram 1500 CC Hemi Sport
What sullivan said. If you use a regular primer or adhesion promoter under high heat paint, it's still going to flake off. I used the 2000 degree (which is definitely overkill) satin black VHT on mine. Just clean them with mineral spirits or some kind of degreaser, scuff, clean again, paint.
BlackedOutHemi
BlackedOutHemi
DFW, Texas
2012 & 2012
Awesome, thanks for all the advice everyone. As soon as it decides to stop being so windy/rainy here I'll be getting this done.
BlackedOutHemi
BlackedOutHemi
DFW, Texas
2012 & 2012
Did just that and it came out great (well, for having no painting experience). A lot simpler than I imagined it'd be.
Lots of tape (newspaper kept ripping)
Emblems getting painted.
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
Looks like those came out pretty good.
truckin151
2013 sport
Not a fan of tips in general but those look good
BlackedOutHemi
BlackedOutHemi
DFW, Texas
2012 & 2012
I like the look of no exhaust tips visible also, but this came with the truck and sounds good. So, I'll keep it for a while. Other more important mods to pay for since I like the sound now.
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Looks nice did you debadge the Ram heads too? I think it would be sweeter if Ram heads were black too.
BlackedOutHemi
BlackedOutHemi
DFW, Texas
2012 & 2012
The front ram head was painted to match when the grille was. So now the back one is off having the same thing done. Should have it back on tomorrow.
Thanks everyone!
mitchman
SC
Looks good. What paint did you use? It looks glossy.
BMRbrnSNRbrd
Norman, OK
That's what I was going to ask Mitch. Mine are the satin black...I like the look of gloss, but I think it would be hard to keep clean. Maybe I'll repaint them.
BlackedOutHemi
BlackedOutHemi
DFW, Texas
2012 & 2012
I ended up going with the semi gloss black. Not any harder to keep clean than the actual truck, so I'm okay with it. As long as everything is dirty together. Lol.
BMRbrnSNRbrd
Norman, OK
Was that pic taken right after you sprayed them?
4XLGATOR
CTD
Those look way better than I expected they would. Good job!
BlackedOutHemi
BlackedOutHemi
DFW, Texas
2012 & 2012
Haha. Thanks. Can't wait for the badge to get done so I can clean her up now and see what they look like then.
stevenmicheal
