Extended Warranty For The Win
rule18
Admin
Administrator
NY
2017 Rebel
I have a fully loaded 2017 Rebel with Four Corner Air Suspension. Guess which part of that sentence this story is about?
A year ago, my Factory 3/36 was about to expire and I planned to keep the truck so I bought a Mopar 6/60 Max Care (which covers everything the Factory 3/36 covered) and paid $1700 in full at the time of purchase.
A month ago I noticed every morning I’d come out to see the front of the truck in Entry/Exit position (front tires very much stuffed into the wheel wells). Once I started the truck, the front bags filled after two minutes or so (annoying AF). Took the truck in for service (I actually LIKE my Dealer, they’ve always treated me and my vehicles right). Three weeks later (parts shortages, whatever) I picked up the truck.
Once the tech removed the compressor assembly, he replaced the valve block, feed hose, vent hoses and temp sensor. Then he refilled the system and let it sit overnight, all good. While the tech was rooting around, he noticed a small bit of oil on the Alternator and traced it to the Timing Cover. Removed cover, replaced gasket. This was an added bonus covered by the original Drivetrain warranty.
The Service Advisor believes that without the extended warranty in force, the Air Bag system repair with parts and labor would have been approximately $2600.00. For me, it was a $100.00 deductable, all in. My advisor saw immediately that the Extended Warranty was in force, and there was never a discussion as to whether any of the issues were going to be covered.
The math says that I’m ahead $800 (roughly), and the Extended Warranty is still in force through 2023 (it’ll be time, not mileage for me).
Obviously this isn’t everyone’s experience with their Dealers or Extended Warranties, YMMV.
MADDOG
Jeeper
Administrator
Apache Junction, AZ
2021 Jeep JL Willys Edition
2.0L 4CYL Turbo
That's exactly my experience with MaxCare warranty packages. I usually purchased the 7/70 plans.
I had to replace two REC/NAV head units (one in the SRT8 and one in the MegaCab) plus an 8.4N in the Bighorn. Cost me a total of $300 ($100 deductible per vehicle) and the retail cost of those OEM units averaged $2300! There were other claims processed under warranty on all three vehicles.
Basically those warranties paid for themselves based on what I saved.
Burla
2010 Hemi Reg Cab 4x4
I guess you can win both ways? I made it 7 years past the original 36 mos warranty and I didn't get extended warranty and I haven't needed it knock wood. So I guess I'm up 1700? So I win to this point, but you still can beat me, maybe you will get lucky and have engine implode and get a new one any day. Just so long as all ram forum members are winning that's all that counts?
jejb
NW Arkansas
I'm glad your extended warranty worked out for you. I bought one for my truck also. But the extended mopar warranty does not cover everything the 3/36 does. You can read your contract to see, but here is some of the stuff under the "not covered" part:
• Exterior - tires; trim; name plates; appliques; body sheet metal; glass; plastic lenses; paint; bright metal; bumpers; side-view mirrors (glass/ housing); wheel covers; steel wheels; aluminum wheels; rusted or frozen rims; weather strips; rust; water leaks; restricted drain tubes; wind noises; all outer body panels; spoilers; plastic and fiberglass body parts; vinyl tops; convertible top fabric; repairs or damage caused by environmental factors such as acid rain, tree sap, salt or ocean spray;
• Interior - trim; carpet; upholstery; dash pad; door and window handles; knobs; buttons; moldings; arm rests and head liner; cargo cover; cosmetic appearance; torn/worn/soiled;
• Mechanical - manual clutch assembly; clutch disc, pressure plate, clutch release bearing and pilot bearing (manual transmission); damage to flywheel as a result of a clutch failure; repairs to snow plows, winches and trailer hitches regardless of their installation;
• Cost or expenses for teardown, rental, inspection or diagnosis of failures not covered by the Plan;
The reason I know is I had a wind noise fixed under the original warranty. They had to reseal the windshield. It came back just after my 3/36 ran out. Not covered now.
Mbrigh3
IG: Stormtrooper_5.7
MD
Shoot it saved me on my 14 I traded in ( Even though I think it was a lemon)
lifetime Maxcare covered:
-a new 8spd transmission at 36k miles
-Manifold bolts
-electric HVAC module
-Second transmission 49k miles
-new catalytic converters
Traded the truck in lol
New ram is 2021 ram is 10 years 100k maxcare
CamperMike
Peoria, IL
I just don't but the warranties. Most times I win. Occasionally I lose... but so far I have saved a ton by NOT buying the warranty. That said I was lucky just recently that my head gasket failed just before the powertrain ran out. Dealer ended up replacing passenger side head and gasket for no cost to me. Also had broken exhaust bolts on the same side fixed. I still won't buy extended warranty.
Smokey613
Foley, AL
Between the Hemi lifter/cam issues and the uConnect system, I will not own a RAM without a MaxCare warranty. But that’s just me. At soon to be 69 yoa, I don’t want any uncovered major expenses on our only means of transportation. We plan to sell this 2018 right before warranty expires and get another one with coverage. So far we have had the wiper motor replaced, soon to have the left seat track replaced and the 8.4 unit replaced. So yes, the MaxCare was a good investment for us.
TerryH
Springdale, AR
2017 Ram 3500
6.7 turbo
My '11 Ram Laramie Sport with 160k and wife's '12 R/T Charger with 140k both have Max Care Unlimited. Max Care has way more than paid for itself on both. They don't sell the unlimited mileage and unlimited time warranty any more. My dealer says it's because of us. lol... We're keeping these forever.
rule18
rule18
Admin
Administrator
NY
2017 Rebel
I've been lucky like that a few times myself, but I couldn't be happier that I bought one this time. Like I said, YMMV.
