External voltage regulator for engine swap
K
Kaelinator
Houston
Do you get no charge if the plug is off of the alternator?
Also check both pins on the alternator and see if one of them gives continuity between the pin and ground (alternator case).
"Started engine by jumping it
Removed ground jumper cable from jeep so that it's no longer getting power from donor car
Voltage kicks up to 17V
I then turned it off. I didn't get the chance to ground that wire that I had jumped from the connector. This is the exact same behavior as if I didn't wire the voltage regulatorup in the first place."
So if I am following correctly, you have + voltage going to one pin 1. Pin 2 is to the voltage regulator only. AND with the plug plugged onto the alternator but unplugged from the voltage regulator - you get 17 V. Correct??
That regulator controls the ground side of the field.
Correct, but now I swapped pin 1 and pin 2 just to see if it'll work.
K
Kaelinator
Houston
my 2001 dakota manual shows it as ungrounded also. Same as the diagram I attached.
Here is a 2006 Ram charging diagram.
It also shows it as ungrounded except by the wiring from the PCM.
I'll be darned. Thank you for this document. I think I'll gonna try swapping the alternator and see if that does the trick. I'll update y'all in the morning. Thank you.
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
I just remember bits & pieces about the charging/ignition systems
Back in the 1950s, they had a Generator , a voltage regulator & a resister, the ignition & the starter.
When i was in the junk yards, i would grab every resister that was handy, if a car did not start & the battery had a charge, we tried the Resister next.
I forget when Mopar first began installing Alternators, but the Voltage regulator was still mounted on the Firewall.
At some point, Mopar was receiving too many complaints, because the Batteries were Over Charging.
The engineers messed around for a while & came up with building an Alternator with the Voltage Regulator mounted Internally
Mopar started using a Computer in 1970/71
I do recall that the Internal Voltage Regulator was controlled by the Computer & the computer will only allow the battery to charge up to something like 85% & then the voltage regulator cuts off.
That kept the Batteries from being over charged
More recently, hot rodders are going back to the External Voltage Regulator, because they need more than 85% of their batteries power
pacofortacos
One more thing that I just thought of - are you trying to run the whole thing without a battery in the Jeep?
Since you mentioned jumping it and removing the jumper, I wasn't sure if you were trying to do this without a battery.
You need a battery and it hooked up for it to work.
K
Kaelinator
Houston
Don't worry, yes, I'm using a battery :)
K
Kaelinator
Houston
Update: I went to O'Reilly's and I tested pin 1 on their alternator. It is grounded, too.
Turns out the '07 is different than the '06 and it can't be controlled using the external voltage regulators. Thankfully the '06 is a direct fit onto the timing cover just like the '07, the only difference is the connector.
blackbetty14
CT
Hemi 5.7 VVT/Etorque
Sounds like a lot of work. Look at adapting another brand/style of alternator that have a simpler activation. With The termX I have on my LS swap i used a factory GM LS alt and used the Single wire harness that just connects to ignition 12v and your done. Your just figuring out mounting and making sure the belt/pulley lines up. Or you can go with a Holley alternator designed for the 5.7 Hemi Truck but doesn't require the factory PCM to work.
blackbetty14
CT
My understanding is that the Hemi has a externally regulated system from the PCM and used PWM to control charging in a closed loop with the battery voltage sensor on the battery + terminal. At least this with the newer 4th gens. In a PWM system Normally the system never sees full ground or full voltage (usually 5v) so the voltage range might be .5v to 4.5 but pulsed at a specific frequency. They style of regulator you have is for an older style system and won't work.
Marshall
Sk, Canada
2014 sport
My suggestion get a good battery, if you are trying to fix electrical issues with ajunk battery that could be part of the problem
pacofortacos
Did you try the 06 then? Work?
If not, I wonder if this regulator would work with the 07.
mrbigbill
Tennessee
So couple things.....I have an 02 ram, alternator failed to full output, with ONLY 1 wire to either field pin alternator goes wide open, thought vr in ecm was gone, tried 2 wire external vr same thing, 19.2v to battery....stepped back and tested from alt case to field pins showing high not infinite ohms, ie a conduction path internally where there shouldn't be causing application of 12v to make alt go wide open, 3 shops later says alt is good.....not making sense so ordered new alt, no meter connection between case and either field pin, installed and everything good now......so double check the alt with a multimeter between each field pin and case ground, if ohms other than infinite appear you have a bad alt from junkyard......if good there, order 2 pin vr from parts store and try......make SURE VR is grounded good and neg cable is also grounded to body frame......dodges are horrible with body/engine/chassis grounds
