Factory air suspension acting up
Discussion in 'Exterior' started by 02blkram47, Nov 22, 2018.
Sponsored By: BAK Factory Outlet
  1. TerraNewf
    TerraNewf Senior Member Supporting Member
    61
    1,334
    439
    Mar 14, 2015
    Ontario, Canada
    Ram Year:
    Engine:
    Do you have any warranty left on your vehicle?
    HitchHiker likes this.
  2. HitchHiker
    HitchHiker Senior Member
    368
    259
    Jul 24, 2016
    Delaware
    Ram Year:
    Engine:
    Yes, it's a 2018 RAM 1500 Limited with 13k miles on it. Plenty of warranty left. :) I looked into the fuse issue and it turns out F5 - the big 40 AMP fuse, was blown. I stopped by the local Auto Zone to pick one up and replaced it right in the parking lot. The front air suspension came right up after doing so. Most likely just a temporary fix though, so I will keep my appt for next week just in case.
  3. TerraNewf
    61
    1,334
    439
    Mar 14, 2015
    Ontario, Canada
    Ram Year:
    Engine:
    I wish mine was that simple, Can you keep us in the loop as to what the dealer tells you? I'm expecting a call on my truck soon. 10 days today since they ordered a reservoir, it was on back order. Seems suspicious when a part that's needed is back ordered. Must be lots needed through out USA and Canada.
  4. HitchHiker
    368
    259
    Jul 24, 2016
    Delaware
    Ram Year:
    Engine:
    Will definitely keep you all in the loop. Was even colder here overnight so still receiving the “immediate attention” alert for the air suspension as of this morning but I’m not on the bump stops yet so hopefully I can last until the middle of next week.
    TerraNewf likes this.
  5. 02blkram47
    02blkram47 Senior Member
    1,147
    138
    Oct 19, 2011
    Lebanon, NH
    Ram Year:
    2018 Ram 1500 Limited
    Engine:
    I've had two straight days in the teens and lower 20s and so far the suspension has held fine.
    Sent from my Pixel 3 XL using Tapatalk
  6. TerraNewf
    61
    1,334
    439
    Mar 14, 2015
    Ontario, Canada
    Ram Year:
    Engine:
    Sounds like you have a good truck and are good to go. There are many more trouble free Air suspension trucks out there. We just don't hear about them.
    02blkram47 and HitchHiker like this.
  7. Brett Knudson
    Brett Knudson Junior Member
    59
    Jan 17, 2019
    Rosemount, MN
    Ram Year:
    Engine:
    It was -26 below Sunday morning up in northern Minnesota. My truck was in the lowered position in the morning and suspension would not work. Made it down the road about 20 miles, couldn't stand the bouncing around, so I pulled into a convenience store to look things over. I removed the 40A fuse and inspected. Air suspension fuse was ok. Started up the truck and the system started working again. My theory now is the system is always on, I can hear it sometimes leveling with the key off. Guessing it went into fault overnight. The truck was fully warmed up and it was still -14 so is it possible that it reset or did I just get lucky?
    BTW, the truck was in service for the same issue last year. They had it for 3-days and never found a problem. Next time it happens, I'll try removing and inserting the fuse. I'll let you know if it works. I might have a chance again Tuesday and Wednesday night. I park outside and the overnight low will be -26 and -31 here.
  8. HitchHiker
    368
    259
    Jul 24, 2016
    Delaware
    Ram Year:
    Engine:
    Did you receive the EVIC notification to have the air suspension serviced immediately? This is what happens with mine on cold mornings. If I let it warm up for several minutes and then cycle the engine the air suspension will usually come online at that point unless the fuse is blown (which has happened twice now).
  9. Brett Knudson
    59
    Jan 17, 2019
    Rosemount, MN
    Ram Year:
    Engine:
    I did get the notification. I didn't restart the truck. I'll try that next time. Maybe it wasn't that I pulled the fuse and re-inserted it. Maybe it was me restarting. Thanks for the tip!
  10. HitchHiker
    368
    259
    Jul 24, 2016
    Delaware
    Ram Year:
    Engine:
    Yep IME the fuse doesn’t have to be reset, but once the truck registers the EVIC notification that the air suspension is not functioning during initial startup sequence, it will not try to reinitiate air suspension startup until you cycle the engine.
Share This Page
