Factory Cam Specs for the Ram 5.7
T Jones
Ohio
Hello everyone. I'm new to the forum, I left a post in the Introductions page. I have a 2014 Ram Express and have always wondered what the factory Cam Specs are on these 5.7 Hemis in the trucks. I also noticed that the 5.7s in the trucks are rated 25hp higher, (395hp), than the 5.7s that were in the Challengers and Chargers of that year, (370hp). So, a couple of questions here if anyone has that info. Thanks in advance.
crackerjack1957
2014 Sport 1500 CC 4x4
Hemi 5.7...65RFE...4.56
392 6.4 VVT Cam Specs 6 speed
215/221 @ .050"
.353"/.333" lobe lift
.574"/.541" valve lift
121 LSA
108 ICL
Stock Eagle 5.7 VVT Cam Specs 6 speed
188/205 @ .050"
243/267 @ .006"
.312"/.304" lobe lift
.500"/.486" valve lift
115 LSA
Stock Eagle 5.7 VVT Cam Specs Auto
186/208 @ .050"
499/493
115LSA
T Jones
T Jones
Ohio
215/221 @ .050"
121 LSA
108 ICL
188/205 @ .050"
243/267 @ .006"
115 LSA
186/208 @ .050"
499/493
115LSA
Thanks buddy. Would those specs be for 6 speed manuals or for 6 speed autos. My Ram is a 6 speed auto.
crackerjack1957
Above was copy & paste from charger forums.com........all the cam specs with 6-speed beside them are non-mds cams (manual trans)
Last 1 was auto......probably car.....have not seen for truck
T Jones
T Jones
Ohio
Thanks cj. I wondered why the 5.7s in the trucks had 25 more hp than the 5.7s in the Chargers and Challengers and thought maybe that the cam profiles might be different. I dunno. Like you, I haven't seen those profiles for the trucks either. Thanks.
Tim Garceau
Banned
Eagle River
2014 Sport Quad BSP
3.92 8 Speed 5.7 4X4
It is the cam profile to go along with the 8 speed and variable intake runners that the 5.7 cars do not have. A 400+hp 5.7 would steal sales away from the 6.4.
Edit-Most people who drove a lightly modded 5.7 would laugh about paying the premium insurance and $8k+ MSRP for the 392.
Nova John
South Plainfield New Jersey
I believe Ram Hemi specs are 186/208 and 499/493 with mds cams having 486 for mds cylinders. also found same duration and 477/471 with mds cams. Reason trucks have 25 more hp is because of better intakes, cold air from front of fender and better flowing exhaust because of more room for better exhaust.
crackerjack1957
Found this also:
Ram stock 5.7 eagle cam
Automatic 5.7
186/208 (4 lobes are actually 205 on the exhaust for MDS)
499/493 (4 lobes have 486 lift on the exhaust for MDS)
115LSA
103ICL
T Jones
T Jones
Ohio
Found this also:
Automatic 5.7
115LSA
103ICL
Thanks cj.
Wonder if it's the same cam that's in the Chargers and Challengers.
T Jones
T Jones
Ohio
Thanks Nova.
MudSkipper
USA
anyone know what the 2003-2008 cam specs are...
I have a non MDS 53021730AB (2005 durango non mds).
Alternate/OEM Part Number(s): 53021730AC, 53021730BA, 53022064AA
MC1397 (Melling replacement part number)
Exhaust Duration: 269 deg
Intake Duration: 259 deg
Cam: Hydraulic
Exh Dur at .50 inch lift 194 deg
Exh Valve lift .451 inch
Int Dur at .50 inch lift 187 deg
Intake Valve Lift:.462
Lifter Type roller
Also 53021731AD(Magnum 5.7 MDS cam) 2005-2008 mds 5.7 cam...
the 2005 durango cam is different...
i am swapping a durango 5.7 block into a Magnum... removing mds... not sure which cam to use?
GOT it you can lookup ALL factory info on Melling. they put out their stock replacement info..
SO the 2005 Magnum cam. MDS only 5 speed
MC1398
Cam: Hydraulic
Exh Valve lift .459 inch
Intake Valve Lift:.472
Lifter Type roller
MudSkipper
USA
The MC1398 cam is good for another 10 horsepower... It was used in MDS up till 2008.
The MC1397 is non mds from 2003-2007 ish(trucks, 2500/3500, others)
