Do ya go to the parts counter or where?Maddog is right about the build sheet. But the OCD person that I am found out that if you make a trip to the local Dodge dealer and give them your VIN they can print out the build sheet with the corresponding letter code. It will also give you such tidbits as a build date for example. I guess it's a result of working too many years in the auto parts industry. I hope this helps.
Welcome to Ramforum, @Camaron32Maddog is right about the build sheet. But the OCD person that I am found out that if you make a trip to the local Dodge dealer and give them your VIN they can print out the build sheet with the corresponding letter code. It will also give you such tidbits as a build date for example. I guess it's a result of working too many years in the auto parts industry. I hope this helps.
