Factory HU relocation
bassheadhemi
Montreal, Canada
Looking into installing a DD in my 15 tradesman equipped with the U5, but still want the ability to change the settings when I want. My idea is to have either the deck relocate or have some kind of quick disconnect to change settings when I want
All I need is the Metra 71-6523 harness and some extra pins for the Metra XSVI-6523-NAV
The plan is only use wires to power up the deck and CAN-BUS. This way I shouldn't need more than 6-8 wires and will be able to use a 8 pin DIN or DB9 connector hidden somewhere for quick connect/disconnect
Anyone knows the connector pinout and what type of pin the male connector use?
Thanks
bassheadhemi
bassheadhemi
Montreal, Canada
Ok quick search on the web and found the needed info for the pinout
1 D75 GY CAN C (+)
2 D177 DB CAN IHS (+)
3 R41 LB/VT AIRBAG DEPLOYMENT SIGNAL
6 X487 LG/LB AUX AUDIO RIGHT SIGNAL
7 X488 LG/DB AUX AUDIO COMMON
8 X40 GY/WT CD CHANGER AUDIO RIGHT SIGNAL
9 X140 GY/OR CD CHANGER AUDIO GROUND
10 X41 GY/WT CD CHANGER AUDIO LEFT SIGNAL
11 D76 YL CAN C (-)
12 D178 WT CAN IHS (-)
16 X486 LG/TN AUX AUDIO LEFT SIGNAL
17 X489 LG/YL AUX AUDIO DEVICE DETECT SIGNAL
29 X792 DB MICROPHONE IN (-)
30 X712 DG/LB MICROPHONE 1 IN (+)
39 X723 LB/TN HANDS FREE MICROPHONE 2 IN (-)
40 X722 LB/DG MICROPHONE 2 IN (+)
43 Z912 BK GROUND
44 A933 RD FUSED B(+)
45 X206 DG/LG RIGHT REAR SPEAKER (+)
46 X202 DG/VT RIGHT FRONT SPEAKER (+)
47 X201 GY/VT LEFT FRONT SPEAKER (+)
48 X205 GY/LG LEFT REAR SPEAKER (+)
49 X296 DG/GY RIGHT REAR SPEAKER (-)
50 X292 DG/YL RIGHT FRONT SPEAKER (-)
51 X291 GY/YL LEFT FRONT SPEAKER (-)
52 X295 GY/DG LEFT REAR SPEAKER (-)
Missing pin are not used apparently.
So I need a total of 6 wires going to the factory HU
Ill also try to tap on pin 39-40 to use the factory mic with my Alpine deck.
more to come :)
bassheadhemi
bassheadhemi
Montreal, Canada
I already have the INA-W910 deck and need an AINET capable deck to be able to adjust the volume from the HU (handsfree too) when paired to the Alpine H800 DSP.
the X009-RAM 3400$ MSRP is also a good reason lol.
