- Nov 21, 2011
- 16,824
- 31,460
- Location
- Oklahoma
- Convert, for now.
- small
if you have the Alpine, yes it takes away and basically sums it to an aftermarket amp. Bypasses factory amp that makes the crossover points.
It's a go betwwwn if you wanted to bypass Alpine amp, and use another amp
I’m not sure what you’re trying to say lol
The Pac eliminates the factory amps, so once you install that you need to use aftermarket amps on all speakers you want to work.I’m not sure what you’re trying to say lol
exactly, the OEM amp determines crossover points, etc for each speaker. This eliminates that, allows you to add an aftermarket amp and tune your way....with no noise added into the system.
Power, and RCAs from PAC to amp, basically just look at it as you bypass or remove the OEM amp.
You'll still need to power amp with a decent wire kit.
and BTW, I do have a new PAC I'm selling.
It shuts the power off from the factory amp and allows it to only be powered by an aftermarket amp. So your highs and mids would be run by the factory amp and like in my case the sub by the JL only.
I’m not looking to add an aftermarket amp. I just want something that will kill the bass that goes to the two front door speakers and will also let me have better control over the factory sub as opposed to just the crappy 3 band eq from the head unit
Checked out the DSR1. It is the same thing as the PAC. It eliminates the factory amp and requires you to run multiple amps to power all the speakers in the vehicle
I don’t believe this is correct. The PAC gives you outputs that you can feed into amps or a DSP. It also will continue to allow the factory amplifier to function as long as it is still connected to the speakers.
https://pac-audio.com/catalog/amppro-amplifier-interfaces/ap4-ch41
