Wow, more great info!
So my 2013 BW 44-44 had red fluid from the factory so I'm assuming thats the Shell Spirax? And thats what the Mopar 44-44 fluid is too right?
Also, Amsoil MVATF did really well in my 44-44 but is that because its one of the pre 2016s?
Yes, your transfer case takes a TES-389/Dexron III(H) or TES-295 class fluid. TES-295 is 100% synthetic ATF with a Dexron III(H) additive package and no manufacturer that has the certification, which runs in the hundreds of thousands, can change their formula without losing their certification. AMSOIL MV SS ATF was the correct fluid for that one, and so is AMSOIL Torque Drive or Redline Oil D4 ATF.
My only concern with Redline C+ ATF would be that it's too slippery and under intense use, it might cause the clutch to burn up. But if you only use 4WD once in a while, it shouldn't be a big deal.
m not in a rush to change my xfer case fluid just yet....differentials Ill do because they are pretty cut and dry. Transfer case (and transmission) Ill let play out in the forums for a little while to see what sticks.
If you drain your transfer case and red fluid comes out, it's Shell Spirax S2 A389, a mineral TES-389 (Dex III) fluid, the same stuff that your municipal garbage truck runs on. If it's amber or has an amber/blueish tint to it, then it's Mobilfluid LT. Mopar is selling industrial ATF and tractor fluid that they buy for like $2~$3 a quart and at a huge premium. If the fluid that comes out is red then you have a huge number of choices. If it's amber/blueish, then you either get Mopar 68049954AC (Mobilfluid LT) or Redline Oil MT-LV. Alternatively, you can get Mobilfluid 424, but it's thicker. The OEM stuff really stinks, and to add insult to injury it's more expensive than premium stuff like Amsoil or Redline. If you go over my previous posts you'll understand why they chose to use two types of fluids, though Mobilfluid LT will work perfectly fine in any BW44-45. I'm gonna do my xfer case in a few days. I'm 99.99% sure that the fluid will be red, but just in case, I ordered both Redline D4 ATF and Redline MT-LV. The transfer case is actually less work than the diffs.
This guy put 80W-90 GL5 gear oil in his BW44-44 transfer case and it worked just fine ... so don't overthink it .... though any soft metal in that xfer case will be corroded in the near future:
