I just installed the high beams... I am not impressed with the installation aspect. The first bulb just needed an adjustment to get it aligned properly (I am assuming they should also be 9&3?), but the second was a whole other ballgame... I tried to adjust it and the little lock screw was stripped out. What I ended up having to do was shave down two of the flaps that go in and turn to hold the bulb in. That was the only way I could get them to fit to be able to turn it the correct way. I was also not able to turn the bulb all of the way in due to it not being aligned properly if I did.
Time will tell if they are bright enough to be worth it tonight, but not impressed with the install...
Also, my pattern still does not look as good as Gregdad's...
