RLJ10X
- Jun 17, 2014
- 1,940
- 1,686
- Location
- Southern Indiana
- 2011
- 5.7 Hemi
Please explain where I said gears would fix the rear end looseness.
He's pulling an 8000 lb trailer. Ram says his truck with 3.21s is rated for 8200. Ram says 3.92 equipped 1500 will pull 10,000+.
If he had 3.92s, he would have 2000 more pounds to go before Ram says that's the limit; Hence more wiggle room (before he's maxed out).
Changing gear ratio still won't change your capacities from a legal standpoint. On paper it is still the same as one that came with 3.92s but for that VIN the max towing will still be 8200 or whatever is was when new.He's pulling an 8000 lb trailer. Ram says his truck with 3.21s is rated for 8200. Ram says 3.92 equipped 1500 will pull 10,000+.
I am curious about what an earlier poster said about the front axle should have less on it than the rear..when my trailer is hooked up I have 100# more on the front axle..3340/3240..seems to tow fine. I use a WDH with the 800# bars..should I be tweaking the rig to change the axle loading somehow.
^^^ what he saidI think what he was saying is to not over-tighten your WDH. Meaning, don't take too much weight off the rear wheels or you can start to lose traction. I had this happen years ago with my first setup. When going over a bump the rear end would lift too much and the wheels would start to break free.
Yes you want to keep the percentage the same. Everything is designed to work best when that is happening.well my thinking is that when not towing 58% of the wt. is on the front axle as near as I can tell by using the numbers off the ram website..but when towing I have just barely over 50% on the front..per cat scale..the steering seems fine but would the whole rig be set up more correctly if more wt. was on the front axle. the WDH could probably be tweaked a little to make that happen..
Thanks for all your help. I think I've decided to just go to a bigger, more appropriate truck. Looking now at 3500's, because I see a fifth wheel in our future. Again, thank you all for your help!
Just NOYes you want to keep the percentage the same. Everything is designed to work best when that is happening.
50/50 weight is not really the whole picture. Weight is the effect of gravity on an object. Engineering designs the braking and steering systems based on the mass of a vehicle. Use of a WDH should be such that the final distribution mimicks the original mechanical set up of a tow vehicle. This ensures the vehicle operates at maximum effectiveness loaded, mirroring how engineers designed it to function unloaded.
Still No..
Find one manufacturer of WDH that spells that out, because if returning back to mimick the factory engineering was important they would.
Even the SAE J2807 recommends a minimum of 25%-50% of the front axle load be returned. Nothing about returning the truck weight balance back to how it left the factory.
If the vehicle design is based on it's mass, then adding a trailer or load completely changes that engineering.
I'd like to see someone contort their 3500 CTD dually w/40' toy hauler set up so the truck has the factory weight balance and report back how it pulls... because that's how it will perform the best? (SMH)..
You are pulling a lot with that truck. Trade in for a 2500. Problem solved. You will go through brakes like poop through a goose with that much weight on that truck. Simply put you are cramming 10 lbs into a bag designed for 5.....
