Fender rust !!!!
C
cpc12
2010 Ram 1500 Big Horn
balls to the walls
Im putting in a kitchen for my wife then Im getting surgeon on this truck.
I will not have fender rust.
creating a flexible hose to get up there too...
Ramtop
2019 Ram 2500
6.4L
Take your taillights out, and you have access to the area above the wheels to clean. POR 15 is a good product, but it is an "after the fact" product. Meaning that you have to already have rust present. Better bet is to get in there and oil undercoat or spray Fluid Film to prevent the rust from happening in the first place.
Ccravillion
Green Bay, Wi
this is what i do
BigA
Ohio
5.7 Hemi Etorque
So here's the picture of inner wheel well looking up from behind the drivers rear wheel. The black part with the cross pattern on it in the lower part of the picture is the back side of the plastic wheel well liner. Right above that is the inner wheel well support. Where the arrow is you can see it is just spot welded to the rear fender and that is where sand/salt will sit and rot the wheel wells from the inside out. The idea is to get the hose up in there to rinse out that area thoroughly. This is also the area where the foam is placed in the 3rd gens. Looks like they left it out on the 4th gens. Also you can see there isnt much for corrosion protection anywhere in here.
Nice picture, I've been pretty good about spraying the underside of my truck at the carwash this winter but that is one area I have not been able to get as you have to pretty much lay down in the slop to get up in their, waiting for a nice day.
moparpeetie
south central PA
just an extra FYI.... NEVER use silicone on a painted surface...actually will create rust & corrosion .... Clean clean clean ...POR-15 as much as you can get at.! :favorites13:
KyleK
5.9 L
Door rust 2nd gen ram
I was just given a 1995 larmie 5.9 L v8 magnum from my grandpa. Its my first car and ive been working on it with my dad, but we have came to the part where the door panels are a little bit rusty. we were just thinking about removing the rust and welding metal to where the rust was and priming and painting it. Good idea or ....?
Hemi395
Cape Cod MA
This will work and is a good idea. Much better than hacking and packing it. Just make sure you grind all the rust off before you prime/paint or it will come through again. Good luck!
Cnypaint34
Upstate NY
Just an fyi for anyone trying the POR 15 route. It does not stick to painted surfaces worth a damn. I repair a lot of rust on trucks and where there is access undercoat like crazy and if you cant get a spray up there, get some wd-40 and get it where the two metals meet.. I spray body Shultz is the best bet but a good rubber undercoating is probabaly 2nd best option.
Sir John
Buffalo, NY
2016 1500 Rebel "Mopar 16" Special Edition
Well, that sucks for all of the guys that have to fix their leaky 3rd brake light. Using silicone sealant is the "fix" from Chrysler. Ford also uses silicone sealant to "fix" the F150 leaky 3rd brake lights. I'm not saying it isn't true, but other than you, I've never heard this before.
DUCKY1090
