finally installed my catch can
hemi8lonestar
Hemphill, Tx
2017 2500 Laramie
finally got around to installing my catch can this morning. i found that i didnt need the spacer on my truck, but i did rotate the rear hose barb up about 2 degrees to allow better run of the hose. i was not really wanting to cross the hoses, but they sure seemed to work better that way.
Casper
U.S. Navy (Ret.)
Springfield, VA
5.7L
Very nice. I'm too OCD to cross the hoses--must be a good Ghost Busters joke/allusion in there.
I trimmed them to make it neat.
Looks good--now you need to lose that factory air box.
hemi8lonestar
hemi8lonestar
Hemphill, Tx
2017 2500 Laramie
i had to hold my OCD in check, believe me. I actually refer to it as CDO, because that's the way the letters should be !!!
chuck
Maryland
2013 True Blue Big Horn
Nice! Looks good! Lol I like the CDO comment too
Roastbeef
Orlando Florida
2012 2500 crew 4x4
i know there is probably a thread about it already but what do you gain by adding a catch can?
GETARAM
Edson, AB
is cutting the hoses to fit not an option? or are these the stock hoses you want to keep...unmolested
VolsRam
Franklin, TN
HEMI 5.7
There are quiet a few threads out there about it as pretty much nobody knew what it was until they joined here. From what I understand, the PCV allows the back pressure air to circulate back into the intake manifold. With this back pressure comes oil, which is being dumped into the intake, mixing with your octane. This in turn will decrease your octane and performance down the road. The catch can allows the air to continue to flow through, but catches the oil that comes with it so it is not circulated through places it shouldnt circulate through.
The hoses are supplied by the distributor and come with the catch can. They are just cut long initially to make sure you're not short changed and need to buy a longer hose. I cut mine to make it look cleaner so there weren't a lot of bends in them, and they didn't cross because of this. Edit: I ordered mine through Moes Performance, a vendor on here. Bully's Performace is another vendor that sales them.
Hope this helps both of y'all
WhiteExpress
Midland, TX
Acceptance into RamForum. That's really all.:hands:
I had the catch can on my '11 for 1500 miles and I had about a tablespoon of oil in it already.
